Last Post 12 Nov 2013 10:16 PM by  drdisque
350z SP question
12 Nov 2013 11:02 AM
    I was under the impression that if your car started in say CS, when you did a modification that bumped you up a class you would follow that class. IE: I changed the wheel size and offset, I would move from CS to CSP. I looked and looked and found an article that 350z's were in BSP, yet I was allowed and advised to run in CSP most of this past year (local solo only).
    During the last race there was another 350z in BSP, he was told to run in BSP. So, which is it and can I maybe get a little explanation of this. I'm not finding anything in the 2013 rulebook about this either, I may be blind but dang, so confusing.
    12 Nov 2013 12:04 PM
    BSP
    /thread.
    12 Nov 2013 01:00 PM
    I understand that now. Was helped out and found the list in the rulebook. But why do they move around like that? Example: a modified 2012 Camaro moves from FS to ESP. Plus I guess from BSP the 350z moves into FP? Does this have something to with how the car reacts to the said limited modifications to street prepared classes? Sorry, I would just like to understand this, as a few of my friends will be joining SCCA next year.
    12 Nov 2013 01:16 PM
    CS->BSP->SSM->FP->XP->and so on
    12 Nov 2013 02:01 PM
    Tell your friends that its foolish to make the assumption that once you buy a letter for a stock/street class to assume that letter will dictate classes further up the line of modification. FYI -- your car now falls in STU if you build it that direction.
    12 Nov 2013 02:44 PM
    The classing systems for solo classification are not linear in nature (even if at some distant time they were intended to be).
    12 Nov 2013 07:57 PM
    Ok, that is where I really went wrong. I was used to a linear classing system. This was the first year I really tried to make events and next year I should be able to make them all. Where I am, I can't seem to get a lot of help in classing questions, well anything outside of what car (stock trim) goes into what class.
    Z3papa: as planned for anytime in the recent future the car will remain in BSP. There are plans to supercharge the car, but that will be years down the road. I first have to catch my driving skill up to the level at which the car performs. I am no where near that point, so I have time.
    Again, thank you very much
    I'm an Admin
    12 Nov 2013 09:27 PM
    350z BSP suspension still for sale
    http://stlouis.craigslist.org/pts/4100377152.html
    Any questions just ask
    SCCAForums.com Admin
    Chris Hammond
    SpecFRS.com
    If your car isn't built to the BSP spec then you may want to read the STU rules. STU is a lower level of prep than Street Prepared. Your car may already be legal for STU or may be legal for STU if you change just a few things. That being said, STU is a pretty fast class and in most regions more popular than BSP, so while STU will get you a softer pax and maybe more cars to run against in your class, it may also mean more really fast cars to beat in your region.
