Last Post 08 Dec 2013 06:57 PM by  froggy47
Update / backdate diff?
froggy47
06 Dec 2013 08:46 PM
    Posting for a friend who runs SP, would the up/back rule allow a bolt in diff swap from cars on the same line?
    Thanks.
    Brigdh
    06 Dec 2013 09:33 PM
    Did you miss the SP rule that allows you to run any diff? I'm not understanding why you are trying to justify a diff swap through update/backdate when there is an explicit allowance.....
    kb_solo2
    06 Dec 2013 10:47 PM
    Posted By Brigdh on 06 Dec 2013 09:33 PM
    Gear ratio's are not free, so that is probably why he is asking about update backdate...
     the answer is yes, you can swap diffs from other years/models on the same line.
    Brigdh
    07 Dec 2013 03:48 PM
    Posted By motoring on 06 Dec 2013 10:47 PM
    If the motivation for the question is to change the gear ratio, then that's not a diff swap, that's a ring and pinion swap and should be specified as such.  Asking accurate questions is how one gets accurate answers.
    So, to be pedantic - diff swaps are allowed because of the explicit allowance.  Ring and pinion swaps are allowed between vehicles listed on the same line due to update/backdate.
    froggy47
    Yes I missed the "any diff" thing, I did read the rules for my pal (he can't read).
    I was asking about the diff not gears, but good to know.
    Thanks.
