Last Post 12 Aug 2014 05:41 PM by  boss002
'01 Bullitt in SM
22 Jul 2014 04:17 PM
    Hi folks, this is my first post here. I have been running autocross up here for the past 8 years. My mods put me in SM as far as I am aware:
     - MM Coil Over kit with Koni SA's
     - Steeda FL subframe connectors welded in
     - MM Panhard Bar and Torque Arm
     - 3:73 gears
     - T2R Diff
     - MM Front A-Arms with Poly bushings
     - K-Frame Brace
     - Rear shock tower brace
     - MM solid steering shaft
     -  a few other small things I cant remember
    As far as I can tell, the only thing I would have to change to get to ESP is the gears....is this corect?
    Thanks
    23 Jul 2014 01:53 AM
    You must remove the coil overs ,gears to 3.55, Torque arm if mounted to subframes, and possibly the steering shaft.
    23 Jul 2014 12:11 PM
    You'd also have to remove the subframe connectors.
    23 Jul 2014 08:38 PM
    Posted By drdisque on 23 Jul 2014 12:11 PM
    Negative. Welded in subframe connectors are legal.
    24 Jul 2014 10:52 AM
    Sorry about that, I see that in the rules. So much for trusting those "what's legal in each class" charts.
    10 Aug 2014 01:22 PM
    So what part of the rules do not allow coil overs conversions in SP class? Is it this...
    "Springs must be of the same type as the original (coil, leaf, torsion bar, etc.) and except as noted herein, must use the original spring attachment points."
    12 Aug 2014 01:42 PM
    Yet 15.8C allows extensive changes to the live axle mounting which could impact the spring mounts and 15.5C allows alternate spring purches.
    So it's less than clear.
    any mustang prior to 2005 can not run a true coil over front or rear until CP. Now you can run the ground control weight jacket style that site on the lower control arm and can adjust.
    SPS 88x31 Button
