Last Post 27 Aug 2014 01:14 PM by  The Nebulizer
Flipping street tires
rgosda
24 Aug 2014 04:18 PM
    So what are the thoughts out there about flipping  street tires?  What is the balance between wearing outside tread blocks, reducing voids, to worn too much?
    Bob G.
    ltborg
    26 Aug 2014 10:45 AM
    I flip mine a bunch to try and keep the wear even.
    twistedwankel
    26 Aug 2014 11:29 AM
    With stock ride height springs and less than -2 degrees camber front and rear on my RX8 and in spec toe in and out I find that I never have to flip the tires on the wheel.  Simply moving the tires front to back after about 6 months keeps them evenly worn.  My latest Rivals don't have a symetrical tread pattern anyhow so they probably wouldn't grip as well if flipped?  I get one season of pretty regular autocross and street driving on a set of 140-200 wear tires here in FL.
    By the time I hit the wear bars they are normally heat cycled out and I get a new set of whatever's best/cheapest.
    My 86 Mustang is even easier with fixed diff and wheel spin no problem keeping tires nice and even.  Those I can rotate twice if needed per year so no way I'll ever have to flip them on the wheels.
    Z3papa
    26 Aug 2014 03:04 PM
    On of the worst experiences I ever had was going to a Tour after flipping tires too late. Tires were undriveable.
    The Nebulizer
    27 Aug 2014 10:48 AM
    It is going to depend a lot on which tire you are talking about.
    Rivals work well flipped (at least in the dry).
    sjfehr
    27 Aug 2014 11:27 AM
    You can swap between left/right wheels on directional tires if you're worried about the tread pattern.
    twistedwankel
    27 Aug 2014 12:48 PM
    My 245mm tires are Rival 3 rib design with narrow inside rib and wider Rivals are 4 rib.  I read somewhere that the Rivals are not suppose to be flipped until worn down to 4/32" or more which is about 1/2 way.  Tread composition?  Don't remember why.  There is a big difference in tread block size inside to outside on the 3 rib design for sure.
    The Nebulizer
    Posted By twistedwankel on 27 Aug 2014 12:48 PM
    Mine were 0/32 outside, maybe 4/32 middle, maybe 5/32 inside when I flipped them (also 245). They work fine.
    I can't imagine a reason for a 4/32 critical threshold for flipping - aside from the tire then being so poor at voiding water at that point that it no longer makes a difference which side is which.
