Last Post 03 Feb 2015 12:19 AM by  cmstrilchuk
Subframe cracks on E46 M3s
sotti
22 Jan 2015 01:36 PM
    I probably shouldn't be too worried since I'll never be nationally competitive, but my M3 just started developing it's notorious subframe mount cracks.
    The fix is to drop everything off the car and weld the cracks and weld up reinforcement plates. Is this sort of thing typically allowed? It's not really a performance improvement, it just keeps the car from tearing itself apart, it's adding weight. With as frequently as these cars are having issues, I would think that this has come up before.
    The Nebulizer
    23 Jan 2015 11:14 AM
    I believe the answer is that it is allowed by the following:
    13.1 AUTHORIZED MODIFICATIONS
    If a modification is not specifically authorized in this or previous Sections of these Rules, it is not allowed.
    The addition of small holes for attachment hardware for authorized modifications is implicit (e.g., holes for fasteners to mount additional gauges, holes for brackets to mount shock absorber remote reservoirs, etc.). However, these holes may serve no other purpose.
    All repairs must comply with factory-authorized methods and procedures, or industry standard methods, as follows: If the OEM does not provide an appropriate method of repair, industry standard methods and procedures may be used. Such repairs may not result in a part or combination of parts that provides a competitive advantage (e.g., significant change to weight, suspension control, power, etc.) as compared to the standard part(s). Competitors are strongly cautioned to use this allowance to make common-sense repairs only.
    The Nebulizer
    23 Jan 2015 11:22 AM
    Confirmed legal.
    This is a specific example used by SEB member to explain the addition of the rule above.
    http://www.sccaforums.com/forums/aft/445930
    landstuhltaylor
    26 Jan 2015 09:54 AM
    This is great news to me. Even after skimming over that section I had assumed adding the reinforcements would not be legal. Obviously common sense applies with not going overboard but it's good to know I have the freedom to solve the issue.
    cmstrilchuk
    Would the structural foam injection in the subframe also be legal, IF it were done preemptively?
    It is / was a BMW repair procedure, so qualifies on that count.
    My common sense says you are not gaining any advantage over someone who had cracks repaired in this manner.
    Curtis
