Last Post 31 Mar 2015 08:13 PM by  Joseph Carozzoni
Struts? - 2012 WRX STI running Street Stock Class
lcdemack
21 Mar 2015 02:51 PM
    http://www.gtworx.com/index.php/gtw...r-sti.html
    Noting the Solo Street (BS) rules basically state, aftermarket struts can be run if geometry of aftermarket strut replicates OEM strut, and springs used are specifically the OEM units.
    Accordingly, does anyone know if the geometry of these Bilstein struts matches the OEM units for the 2012 STI wagon?
    OZMDD
    24 Mar 2015 04:39 PM
    Its on you to ensure dimensional compatibility. Break out a ruler and take lots of measurements.
    tuskenraider
    24 Mar 2015 08:00 PM
    "These dampers also provide an excellent option for stock class autocrossers looking for an OEM fitment damper that has firmer damping and large amount of gas pressure to pair with stock springs." In the description.
    And yes, I do know these to be legal.
    Joseph Carozzoni
    Posted By tuskenraider on 24 Mar 2015 08:00 PM
    From the link: "The rear shocks feature an adjustable CIRCLIP for + 5 mm, +10 mm or -5 mm, -10 mm rear ride height."
    From the rule book: Reference 13.8 A & B you cannot use this feature of those shocks - but yes everything else is legal.
    Note that for about $100 average per strut/shock, you can send your current Bilsteins (if so equipped) to Bilsetin and revalved to those specs.
