Last Post 30 Mar 2015 06:26 PM by  djm1968
Wheel spacers
djm1968
30 Mar 2015 05:08 PM
    I run my '12 Cayman R is Super Street and am looking to
    According to SCCA rules, I am allowed to use wheel spacers of +/- 7mm. Porsche offered 5mm spacers as an option for my model, which I am allowed to add to the 7mm already allotted by the rules, correct? My track wheels have 2mm less backspacing than the OEM wheel, so minus 2mm of spacer would be required to compensate, correct?
    7mm per SS rules on using spacers
    5mm per SS rules for OEM spacers
    -2mm for using wheels with 2mm less backspacing.
    10mm
    Are my calculations correct?
    DJM
    Joseph Carozzoni
    30 Mar 2015 06:02 PM
    "Wheel spacers are permitted provided the resultant combination complies with the offset requirements of this Section. On vehicles supplied with an OE wheel spacer, the wheel spacer shall be considered as a part of the wheel."
    I would say yes. Just make sure that the Wheel Spacer Option changed absolutely nothing else that cannot be changed legally. For example, if the Wheel Spacer Option also included a quicker steering ratio (which you cannot legally change) - then no.
    djm1968
    Posted By Mario Linguini on 30 Mar 2015 06:02 PM
    Thanks for the note and, at least on the Cayman R, selecting the wheel spacer option changed absolutely nothing else.
    Cheers,
    DJM
