Last Post 22 Jun 2015 01:20 PM by  Grintch
Class question - '15 Mustang GT
kz
22 Jun 2015 08:28 AM
    Need some help determining the class for my car - I'm just starting, all I've done so far was to take Starting Line class.
    '15 Mustang GT, non Performance Pack car. Added OEM strut tower brace (a while ago) which is standard on Performance Pack GT Mustang car (which mine is not).
    Does the brace put me in STU or CAM-C then ? (not that it really matters at this point as I'll be out there for learning mostly).
    drdisque
    22 Jun 2015 10:45 AM
    Technically these are your two options: You can put on everything else that came in the Performance Pack and stay in FS, or you can run in STU or CAMC. Now in reality most people probably won't care.
    Also, the brace isn't really doing much for you, so you could even take it off. That's the easiest solution.
    Grintch
    Or ESP.
    At the local level no one is likely to care. If you want a National trophy, take it off or add a lot of mods to fit in your new class.
