Last Post 01 Jul 2015 05:40 AM by  sjfehr
Best Tire for STS Miata
JsnMR2
30 Jun 2015 10:37 PM
    I'm tired of beating on my daily driver, a 2015 Audi S3 that I am currently running in ASP because of my APR stage 2 tune. That being said, I'm buying a friends fully prepped STS Miata.
    I ran a 50.1 in my S3 at the last event, while the owner of this miata ran a 50.07. He let me do two fun runs in it, and I ran a 52 followed by a 50.7. I feel I had some room to grow still being that I never drove a Miata before.
    It currently has 200 tread wear 195/50/15 RS3's on it. Last year, he ran 140 tread wear R1R's. The rim is 15x7.5. I see that the new 200 tread wear R1R's are available in 195/50/15 now.
    So what do you think?
    195/50 200 tread wear R1R's? (I'm assuming these are the same old 140 tread wear compound, re stamped with a 200)
    195/50 200 tread wear RS3's again?
    205/50 Bridgestone RE-71R? (Not available in 195)
    This would not be a daily driver at all. Purely for auto cross use. As long as they will last a full season with one driver, wear is not a concern.
    The S3 is on RE-11's which I enjoy.
    I know R1R's use to be the go to tire it seems. Just not sure about how they stack up now.
    Thanks!
    sjfehr
    If you want to be competitive, your two tire choices are RE-71R or Rival S. Either should work well for an STS Miata. If it's set up right now for Toyo, would probably be an easier transition setup-wise to Rival S, but the RE-71R are going to feel a lot like your RE-11.
    No need to stick to the pixie dust 195 if you're leaving Toyo; go as wide as you can get while staying legal.
