Last Post 08 Jul 2015 03:01 PM by  the3lracer
Magnus effect aero
the3lracer
07 Jul 2015 11:00 PM
    So one of my friends running in SSM is toying with the idea of creating a rear wing designed to make use of the Magnus effect (https://en.wikipedia.org/wiki/Magnus_effect). This would be, in some way, powered by an electric motor (I'm guessing some sort of belt-driven system). The system would spin at a constant velocity and could not be switched on/off while the vehicle is in motion.
    The $10,000 question is, would this be legal in SSM (or any class, for that matter) if it could fit into all of the documented constraints? (I know well the rule of "if it doesn't say you can, you can't", but to me it is not clear if this fits the constraints set forth in the rule book)
    Other questions include:
    -Would it be SSM (or any class) legal to rig up a Magnus effect "wing" on the FRONT of the car?
    -Would you need to consider the entire surface area of the rotating cylinder in the wing surface area calculation, or only half of it?
    -Would this actually be an effective method of generating downforce at all?
    drdisque
    08 Jul 2015 12:28 PM
    I don't think that an autocross car moves fast enough for this to work better than existing methods and I also believe that airfoils that "move" are illegal.
    the3lracer
    The exact phrasing of the rule pertaining to moveable aero in SSM reads "Except for standard parts, wings designed to be adjustable while the car is in motion must be locked in a single position."
    This is why I provided the stipulation of the constant velocity of the spinning cylinder, as well as the inability to turn it on/off while the vehicle is in motion.
    I know no one locally is going to protest him trying it, so if he can figure out a way to make it work and be effective, he's going to do it.
