Last Post 11 Jul 2015 06:43 PM by  spitfire4gp
    The perks are:
    The necessaries are:
    1. Your name
    2. Mailing address
    4. e-mail address
    Hope to hear from you soon!
    --Rocky Entriken
    Chief of Writers
    ~~~TUE-WED~~~
    SSR BS ES FS HS
    STS
    CAM-(all)
    SSP ASP BSP CSP DSP ESP
    SSM SMF
    XP DP EP
    AM FM FSAE
    ~~~THU-FRI~~~
    SS AS CS DS GS
    STF STR STX STU
    FSP
    SM
    CP FP
    BM CM DM EM KM JA/JB
    G-Loc Button
