Last Post 28 Feb 2016 06:10 PM by  dhrmx5
T3 LEGAL SPEC E46 "KIT" FOR SALE
BMWRACER07
09 Feb 2016 04:59 PM
    Fellow racers
    I hope this is the correct place for cars for sale. If it isn't I'm sure someone will let me know and I will change it.
    We've had a change of plans pertaining to our second Spec E46 car.
    It's up for sale as a kit 8-)
    The interior's been stripped, the cage and sunroof panel has been installed and the interior professionally painted (silver, like the car)
    Some of the engine stuff has been done. I'm selling it as a kit for $19,500 OBO.
    If I get no interest I'll finish it off and sell it for more.
    Here's where I'm at on the car:
    Car..... $4500
    Cage.....$3500
    Bimmerworld parts (all new, but not installed yet)
    Diffsonline diff (The $2999.99 one)
    Finned diff cover
    Oil pan baffle
    Upgraded oil pump
    Tilton Clutch/flywheel
    Spec springs
    Rear spring purches
    Camber plates
    Hotchkiss bars
    Trailing arm bushings
    Adjustable rear lower control arms
    Rear shock mounts
    Rear subframe bushings
    MCS spec shock setup
    Front control arm bushings
    Front subframe reinforcements
    Rear chassis reinforcements
    BMW strut top plates
    Brake hoses
    Solid diff mounts
    Clutch pedal stop
    Heater hose deleat
    Anti surge fuel pump (installed)
    wheel studs and nuts
    Spec exhaust system
    4 Apex wheels
    EPIC spec computer flash
    CF sunroof panel (installed)
    That came from the "build sheet" all the prices and info is here:
    https://docs.google.com/spreadsheet...li=1#gid=0
    I went with the middle "Typical build" with the exception of the clutch/ flywheel and the diff.
    Total for Bimmerworld parts is $14,316.00
    Other parts include:
    Used exhaust manifolds (installed)
    Window net mount
    New Old stock Cobra Evolution Seat
    Quick disconnect hub
    Hawk Brake pads
    Total Parts from GT International Motors $3055.31
    You are looking at about $27,000 worth of parts and car.
    Not including any labor to get to this point
    Let me know if you have any more questions
    John Norris
    johnnorris(at)earthlink(dot)net
    dhrmx5
    Sounds like a great buy. There is a cars for sale section further down.
    G-Loc Button
