AspireTec Engineering  468
Last Post 18 Mar 2016 05:05 PM by  Z3papa
Rantoul on March 19th
Lethal_427
11 Mar 2016 01:20 PM
    Anyone in the STL area heading up to Rantoul on Saturday March 19th for the event that could haul a set of tires up with them?
    JJ
    sgreer78
    11 Mar 2016 01:28 PM
    I might go. If I do, I will. I know that's not a concrete answer, but that's all I got for you right now. If it rains Sunday, I'll be going for sure.
    Lethal_427
    11 Mar 2016 01:41 PM
    Thanks Sean, I appreciate it! I will have the tires dismounted at Dave's place and I could check with Dave about leaving the tires at his place to pick up if that works for you?
    If anyone else is willing, let me know. Wouldn't mind having a backup in case Sean doesn't make it up.
    JJ
    drhodes
    11 Mar 2016 05:59 PM
    I'm going it's just a question of will I have a trailer in time to pull the s2000 up. On that note, I need a trailer.
    TD53
    15 Mar 2016 05:02 PM
    Please warm up, please warm up, please warm up....
    Matthewm3
    15 Mar 2016 05:14 PM
    I'd like to go but if the forecast doesn't change I'm out.
    Z3papa
    16 Mar 2016 10:16 PM
    It's slated to be 48 or 49 degrees and is still winter. Pretty damn good, If that's not warm enough, winter autocross may not work for you in the midwest. Otherwise, look forward to seeing you.
    sgreer78
    17 Mar 2016 11:16 AM
    And spending an entire day in the cold wind, driving to and from, and then getting up the next morning to do it again locally...It's not as simple as only the temperature.
    Z3papa
    Posted By sgreer78 on 17 Mar 2016 11:16 AM
    You're right Sean.  I never considered those other factors. :)
