Last Post 20 Nov 2017 10:44 PM by  xander
RE 71 tire pressure
Cactus Bob
27 May 2016 10:03 PM
    Any tire pressure recommendations for RE 71's on an A Stock C-5 Z-06 Corvette?
    Changing from Rivals.
    Thanks.
    apexjunky
    16 Aug 2016 04:29 PM
    I've been running super high psi's in our DS WRX - 38F and 42-50 rear PSI, but we also have very limited camber in the car...
    drdisque
    16 Aug 2016 08:11 PM
    Yes, I can second the limited camber needs a lot of pressure.
    I was running 36-39 in my BMW and my friend who has an ES NB Miata told me to try lower as he was usually in the mid-high 20's. I tried 30-31 and the fronts were flopping all over themselves. Back up to high 30's I go.
    Anyway, both of those are probably pretty useless for a C5 Z06, which is a heavy car but not camber challenged. So if I had to take a swag I'd guess mid 30's.
    cretinx
    17 Aug 2016 11:41 AM
    As low as you can without rolling over.
    The sidewalls are bonkers stiff on the RE71r.
    jwdsail
    27 Jun 2017 09:58 PM
    On my C6, I'm running ~30-31 Front, 27-28 Rear, depending on surface and how tight the course is... Running allot of camber and caster however...
    xander
    Posted By jwdsail on 27 Jun 2017 09:58 PM
    We recently worked on new brake pad and nitto tires on a C6 and run the same tire pressures. The owner felt a good difference.
