Last Post 16 Jul 2016 01:28 PM by  greghavener
1988 CRX Si for STS - Lower Price
12 Jun 2016 10:36 PM
    1988 Honda CRX Si - $2,750 PRICE LOWERED
    Greg gbhavener@mchsi.com
    Jefferson City, Missouri
    This is the lightest year and it is built for STS.  I brought the car from Florida.  The only rust is what you can see.  The sunroof and rear fenders are the typical rusty spots, but the undercarriage is rust-free and solid.  The seats have been patched, not my best work.  The climate controls have been rebuilt and work fine.  The condition is pretty good for a classic car. Enjoying how it handles and runs has always been my first priority.  Bodywork and paint would finish this classic car.
    This car is a lot of fun, it is always pretty quick on course.  It hasn’t seen an autocross in 4 years doing time as a daily driver.  My “local” autocross site is 100 miles away.  To keep from pushing it home, maintenance has been the plan.  I would not be afraid to hop in it and drive across the country tonight.  It gets 40 mpg on the road and parts are relatively cheap.
    It doesn’t smoke or use any oil, Mobil 1 since I’ve had it.
    304,XXX miles  original engine/no sign it has ever been rebuilt
    Gearbox has gotten new seals and bearings, works like new
    Urethane shifter bushings
    Remanufactured half-shafts
    All new wheel bearings
    New upper/lower ball joints
    New inner/outer tie rods
    New Drums and Rotors
    New rubber bushings in front control arms (I haven’t installed the ones for the rear)
    New Rear Trailing Arm bushings
    New Water Pump and Water Pipe
    New Timing Belt and Pulleys
    Front and Rear Main Seals
    New Spark Plugs, Wires, Cap, Rotor
    New Clutch Disc, Pressure Plate, and resurfaced Flywheel
    New Speedo cable
    New Ignition Switch
    New Heater Blower Relay
    New Thermostat, Rad Hoses, Heater Hoses, Belts
    New Fuel Filter
    STS Performance Parts
    Aluminum Crankshaft Pulley
    Cold Air Intake that originates behind the bumper
    Header, HiFlow Cat, and DynoMax street muffler (V Band disconnect behind axle)
    RedShift ECU
    HPS Plus front brake pads
    Stainless Steel Brake Lines
    Koni Shortened Race Valved Shocks with Ground Control Coilovers 450F/550R
    Suspension Techniques Rear Sway Bar
    Adjustable Front Control Arms/Rear Camber Adjusters
    320mm NRG Steering Wheel/Momo Hub
    Simpson 5 Point Harnesses, only the Lap Belt is (clip) mounted
    Kirkey Econo-Drag Seat 10 Degree Layback 15 inch mounted on factory sliders (Factory Driver’s seat included, swap the whole unit for street use)
    Mutekei open-style steel spline lug nuts
    Miata Wheels for daily with Falken Tires
    I’ll include one set of Enkei RPF-1 Wheels 15X7 41offset 9.5 pounds each.
    13 Jun 2016 08:29 PM
    13 Jun 2016 08:37 PM
    [URL=http://s244.photobucket.com/user/BanzaiBeast/media/100_1892_zpsqqstfhhu.jpg.html][/URL][URL=http://s244.photobucket.com/user/BanzaiBeast/media/100_1878_zpsqoerx7ao.jpg.html][/URL][[URL=http://s244.photobucket.com/user/BanzaiBeast/media/100_1891_zpsczkant9g.jpg.html][IMG]
    22 Jun 2016 11:10 PM
    Price Drop to $3,100
    01 Jul 2016 10:41 PM
    Price reduced again to $2,900 must sell soon. I am moving across the country.
    07 Jul 2016 09:51 AM
    I'm interested, but am up in Wisconsin. Any way to ship/transport to Milwaukee area?
    10 Jul 2016 11:09 AM
    Still For Sale
    I am moving across the country and can't keep it.  Gotta sell this week.
    13 Jul 2016 07:35 AM
    Lowered price again $2,750 for everything!
    14 Jul 2016 12:37 PM
    I'm interested and not far away call 785 633 9399 or 785 272 3232
    Thanks
    Thanks
    14 Jul 2016 10:11 PM
    Sale Pending.
    Sold!!!!
