Last Post 18 Sep 2017 07:39 AM by  KeithB
Sold - '72 Datsun 240Z - F-Prepared - $11k - Maryland
KeithB
05 Feb 2017 02:07 PM
    Sold
    Chassis
    1972 Datsun 240Z
    Full Bolt-in Rollcage
    Fender flares
    Seam welded engine bay
    Custom Paint and Vinyl
    Engine
    Former SCCA GT2 Road Race Motor (Rebuilt Spring 2011)
    13.5:1 compression ratio
    Shaved/Ported E88 Cylinder Head
    F54 Block w/ Carillo Rods & JE Pistons
    Schneider Autocross-grind Camshaft
    Arizona Z Car Cast Aluminum Oil Pan
    New Weber 45 DCOE carbs
    Set of Mikuni 44mm Race Prepped Carbs (40mm venturies) (need refurbished)
    Cannon Intake Manifold (port matched)
    Stahl 6-2-1 Header
    3.0" Custom Exhaust, Magnaflow Muffler
    Electromotive XDi Crank Trigger Ignition
    Rebello-BHJ Harmonic Damper w/ Trigger Wheel
    Griffin Aluminium radiator
    Front-mounted Oil Cooler, thermo-controlled
    Mallory Comp-110 Fuel Pump
    Drivetrain
    Stock 240Z 4-Speed Transmission
    MSA Short-Shift Kit
    Fidanza Aluminum Flywheel
    Spare Fidanza Flywheel friction plate
    ACT Pressure Plate
    ACT Solid Puck Clutch Disc
    Spare ACT Pressure Plate
    Spare ACT Solid Puck Clutch Disc
    R200 Limited-Slip Differential (from Turbo 300ZX)
    Wolf Creek Racing CV Axles
    Modern-Motorsports Rear Stub Axles
    Suspension/Brakes
    Ground Control Coilovers
    450# Eibach Springs Front
    500# Eibach Springs Rear
    Also 350# and 400# Eibach springs
    Koni 8610-1437RACE Shocks
    Ground Control Front Strut Tower Bar
    Ground Control Front Camber Plates
    EMI Racing Rear Camber Plates
    Custom Triangulated Firewall Bars
    Arizona Z Car Billet Aluminum Control Arms Front
    Aluminum/Delrin Suspension Bushings Rear
    Modern-Motorports Aluminum Front Hubs
    MSA Slotted and Drilled Front Rotors
    Modern-Motorsports Rear Disk Upgrade (240SX calipers)
    Hawk HP+ Brake Pads
    Tires/Wheels
    Real Racing Aluminum Wheels 16x10
    Avon Bias Ply Slicks 11.0/23.5-16 (A11 compound)
    SportMAXX Rain Wheels 15x8
    Hoosier Road Race Wets (23x9x15)
    Real Wheels 15x10 (no tires)
    Interior/Safety
    Driver Seat 17" Kirkey Intermediate Road Race
    Passenger Seat Ultrashield Rally Sport Seats 16"
    Also have a Ultrashield Rally Sport Seats 15"
    Simpson Camlock Racing Harnesses
    Jegs 5-gallon Aluminum Fuel Cell
    Custom Fuel Cell Cage
    Custom Gauge Cage w/ Autometer Oil Pressure/Oil Temp/Water Temp
    Innovate LM1 Wide-band AFR
    Autometer Fuel Pressure Gauge
    Car is 10# over minimum wieght (without driver) with 1.5 gallons of fuel
    Scaled and aligned
    All the car needs is a some final carb tuning
    XP in the pictures is a magnet, FP is under the XP magnet
    I bought the car with hopes of doing some national events.
    It doesn't look like that is going to happen, I don't need 2 cars,
    so I've decided to sell this one.
    Vintagezracer
    06 Feb 2017 07:12 PM
    Interestedin the Z.
    Would like to discuss.
    Can you send contact info to
    DocBRacing "at" AOL
    Thanks!
    Tom
    Vintagezracer
    06 Feb 2017 11:13 PM
    Interested in the Z
    If possible, please PM me contact info so we can discuss further.
    Thanks!
    Tom
    KeithB
    04 Apr 2017 02:56 PM
    Still for sale...
    Racy1
    19 Apr 2017 09:12 PM
    Hi, Is the car still available ?
    Racy1
    KeithB
    19 Apr 2017 10:37 PM
    Hi,
    Yes, still available.
    KeithB
    12 Jun 2017 12:53 PM
    Still for sale... Really want to move this. Let's make a deal!
    KeithB
    Aaronsti
    17 Sep 2017 08:00 AM
    Hi, very interested in the car. Email me at aaskolnik@yahoo.com
    KeithB
    Sold.
