Last Post 15 Jun 2017 01:25 PM by  mtnmen59
2001 Spec Miata
    Race Ready   2001 Spec Miata
    Tub up build 2015   Dark metallic blue, acid green stripe, top, roll cage & wheels.
    Competitive car in SCCA, NASA and World Racing League
    Tech inspected and approved for SCCA, NASA and WRL log book available.
    White interior, engine compartment, trunk and underbody, Miata cage w/nascar bars, acid green
    New OMP 5 point harness exp 2022   original OMP 5 point harness exp 2019
    New OMP WRC-R seat – black - fits up to 38” waste size exp 2022 / Sparco brackets and sliders
    Original Sparco REV GRP Tech – red - 32” waste size included exp 2019.
    Driver seat floor pan lowered 1” to facilitate more head room and to accommodate taller drivers.
    New OMP flat bottom steering wheel and quick release, original OMP round steering wheel and quick release. 2 steering wheels to accommodate driver comfort in WRL events.
    Autometer  water and oil pressure gauges / AIM Solo DL
    Manual Steering Rack  Mishimoto radiator + Dual Switched Fans, HID headlight and driving lites for night racing.
    3 sets 15 x 7 Team Dynamics Wheels, acid green
    New, less than 30 min track time Dunlop Direzza 205/50/15 WRL tire
    New, Maxxis Victra RC-1 10 minutes of autocross time 205/50/15 Super Miata spec tire
    2 New sets of Hoosier H2O SCCA rain tires 205/50/15
    3 - 5 speed transmissions one in car fresh reworked 3hrs run time / other 2 tranis likely need 3rd gear shift forks.
    New / reworked LS Diff 4.3 gears 3hrs run time in car.
    New / reworked LS Diff 4.1 gears 0 run time.
    2 sets Spec Miata Springs and Shocks (Bilstein & Eibach), adjustable sway bar links.
    Additional set of front and rear sway bars.
    2 complete professionally built motors by DC Racing engines. w / ACT clutch,
    Motor 1 built to Spec Miata specs w/overbore 25hrs run time.
    Motor 2 built for WRL & Super Miata competition, minimal head and block decking / ported intake, overbore pistons, aftermarket valves and custom seating.  3 hrs run time.
    Stock header with MBS Mandrel Bending Solutions Exhaust.
    Motor 3 New Spec Miata overbore short block, untouched head and all parts
    Other new, used or original spare parts from 3 cars
    Fire extinguisher, corvette net, window net, 16” rear view mirror, New 2016 Optima battery, stainless break lines, New rear axles, 2 sets New front Brake discs, 4 New Timkin front wheel hubs w / long lug studs, 1 spare manual steering rack, oil pumps, water pumps, starters, alternators,    2 ECUs, motor mounts, wiring harness, fuse box, motor wiring cluster, brake calipers, rear diff bushings, speedo sensors, OEM clutches, drive shafts, rear axles, New swing arm bushings, clutch master, brake  master, tie rod ends, ball joints, New shock mount bushing, New coils spring bracket, air boxes, swing arms / control arms, painted front & rear bumper, quarter panels, doors.
    2001 – 22’ US Cargo trailer, side door, rear ramp door w/aluminum ramps, custom storage cabinets, locker and wheel / tire clamping system. 4 New tires and full brakes job 2015, includes 2” receiver and anti-sway / bounce bar system. New rear led lights trailer is in excellent condition.
    Turnkey package! Car, parts, pieces and trailer $35,000.00
    Contact Randy at for pictures or call 970-497-0691  Denver Colorado.
