Last Post 19 Mar 2018 09:22 AM by  mestuneup
WTS Radical SR3 Quaife PowerTec gear drive system
mestuneup
29 Jun 2017 02:16 AM
    Price 4400$ exclude ship
    contact +66801589988
    email r.pongphluk@gmail.com
    Quaife PowerTec gear drive system is suitable for use with most super-bike engines. The unit simply bolts directly to the side of the engine. Power is transmitted directly from the output shaft via a unique cushion drive coupling. Drive is then taken through a pair of quick-change reduction gears to the Quaife ATB differential. An integral reverse gear system is activated by a push-pull cable. Quaife PowerTec gear drive system incorporates a gear drive system which was designed jointly by Powertec and Quaife Engineering for the award-winning Radical SR3. Direct drive from gearbox output shaft.Uses cushion drive unit for smoother transmission.Quick change reduction gears with various ratios from 2.9:1 to 3.6:1.Cable push-pull operated reverse.Uses easily available joints and shafts or drive shafts made to suit your application.
    mestuneup
    In the process of trading
