Last Post 02 Sep 2017 06:47 AM by  RX555
1999 Pontiac Firebird - SCCA T4/ITR
dhardison
08 Aug 2017 08:12 AM
    SOLD! SOLD! SOLD!
    Ready to race in T4 & ITR (as is) or swap in a carb'd SBC or LS1 and run in A-Sedan. Car is SUPER clean and needs NOTHING to hit the track.
    Originally built/tuned/raced by Phoenix Racing (raced by Don Knowles in 2014/2015). I purchased the car from Phoenix Racing mid-April 2016, raced six events in 2016 (2nd in GLDiv T4 points) and three events in 2017 (last event was June 2017). Easy on tires (average ~8 heat cycles on Hoosier A6s and ~10 heat cycles on BFG R1-Ss) and not bad on brakes (6-8 sessions depending on track). Car is very predictable/forgiving to drive with no surprises. Post-race weight average is ~3230# with 230# driver (max spec weight = 3250#).
    Engine
    3.8L V6 (stock per T4 rules, but tuned by Phoenix Racing - HPTuners)
    204whp/235wtq (have dyno sheet)
    K&N Cold Air Intake Kit - FIPK #57-3041
    Custom Phoenix 3" exhaust
    GM P/S cooler
    Trans
    5-speed (stock per T4 rules)
    GM clutch/PP
    Suspension
    Koni Yellow single adjustable shocks - #8241-1139 (F), #8241-1140 (R)
    Strano front and rear springs - #SP-141
    Strano front sway bar - #SP-8316 (F), #SP-8327 (R)
    BMR suspension strut tower brace - #STB-002
    Limited slip differential - 3.42 gear
    Extended wheel studs front/rear
    Brakes
    Stock F&R
    Braided SS brake lines
    3" fresh air brake ducts
    Factory ABS
    Interior
    Phoenix built custom roll cage
    Cobra Imola "S" FIA racing seat (adjustable)
    Scroth FIA 5-point, cam-lock belts (good through 2018)
    Racing steering wheel (T/W for easy exit)
    Concave rear and side bubble mirrors
    Handheld extinguisher
    Main kill switch
    Left window net
    Right side net
    Wheels/Tires (all below are mounted on OEM 16x8 Firebird/Camaro wheels)
    (4) mounted with BFG R1-S 275/45/16 (1 session)
    (4) mounted with Hoosier A6 245/45/16 (2 sessions)
    (8) mounted with Hoosier A6 245/45/16 (8 sessions)
    (4) mounted with BFG Rival-S215/45/16 (brand new - intermediates)
    Other
    **Includes hard-wired "no subscription" AMB transponder!
    Full set of GM service manuals
    Plexiglass side-window inserts (used when towing on open trailer)
    Spares
    (2) Koni rear shocks #8241-1140 (like new)
    (1) Hawk DTC-70 brake pads - front (NEW)
    (10) Hawk DTC-70 brake pads - front (used/usable)
    (2) new Stoptech brake pads - rear (NEW)
    (1) Hawk HTC-10 brake pads - rear (used/usable)
    (1) Brake rotor - front (NEW)
    (2) Brake rotor - rear (NEW)
    (2) Brake rotor - rear (used/usable)
    (4) Wheel bearings - front (used/usable)
    Factory air intake with K&N drop-in filter
    Misc. wheel studs and lug nuts
    $8500 obo - MOTIVATED SELLER
    dan_hardison AT yahoo DOT com
    7 four 0 - two 6 three - 4 zero 9 zero
    Links to MANY PICS BELOW
    Exterior pics
    http://www.danhardison.com/t4_firebird/ext1.jpg
    http://www.danhardison.com/t4_firebird/ext2.jpg
    http://www.danhardison.com/t4_firebird/ext3.jpg
    http://www.danhardison.com/t4_firebird/ext4.jpg
    http://www.danhardison.com/t4_firebird/ext5.jpg
    http://www.danhardison.com/t4_firebird/ext6.jpg
    http://www.danhardison.com/t4_firebird/ext7.jpg
    http://www.danhardison.com/t4_firebird/ext8.jpg
    http://www.danhardison.com/t4_firebird/ext1a.jpg
    Interior pics
    http://www.danhardison.com/t4_firebird/int1.jpg
    http://www.danhardison.com/t4_firebird/int2.jpg
    http://www.danhardison.com/t4_firebird/int3.jpg
    http://www.danhardison.com/t4_firebird/int4.jpg
    http://www.danhardison.com/t4_firebird/int5.jpg
    http://www.danhardison.com/t4_firebird/int6.jpg
    http://www.danhardison.com/t4_firebird/int7.jpg
    http://www.danhardison.com/t4_firebird/int8.jpg
    http://www.danhardison.com/t4_firebird/int9.jpg
    http://www.danhardison.com/t4_firebird/int10.jpg
    Engine pics
    http://www.danhardison.com/t4_firebird/eng1.jpg
    http://www.danhardison.com/t4_firebird/eng2.jpg
    RX555
    That's a smokin' deal. GLWS
