Last Post 16 Aug 2017 01:34 AM by  centanni
FS: 2002 Corvette Z06, Electron Blue, stock – Austin TX - $15,900
centanni
    For sale 2002 Chevrolet Corvette Z06:
    ~126k on the chassis, with ~54k on the motor (crate LS6 motor from GM when it was replaced at 72k miles)
    Interior is in good shape with only the typical small tear in the drivers side seat bolster (can be seen in pic)
    New full paint job from Jeff's Autobody in 2015 (very good reputation in Austin area - previous owner, also a friend of mine, had it re-painted original color Electron Blue due to the car getting egged by some neighborhood kids - several panels had spider cracks in the clear coat from that)
    New OEM water pump installed ~3k miles ago (Summer 2015)
    New GM factory differential installed ~5k miles ago (Spring 2015)
    New Wheel hubs/bearings all around installed within last ~15k miles
    Shocks from an '04 Z06 installed ~20k miles ago (Fall 2014)
    New OEM clutch installed ~25k miles ago (Spring 2014)
    New A/C system installed Summer 2013 – still blows very cold.
    Bluetooth / CD audio system installed
    Now for the one bad thing first - the first gear synchro is dead, so from a stop, you have to slip it into 2nd, then up to 1st so it doesn't grind.  Other than that its in good condition with a good number of new parts.
    The car is pretty much bone stock, and kept up with replacing anything that went bad.  Car runs and drives strong and is still driven regularly.
    Current Registration and Inspection
    Clean title in hand.
    A few extra things I’ll include for fellow enthusiasts if interested for the price below:
    Extra set of black C6Z style wheels (in C5Z sizes)
    Used Koni Sport Shocks - Single Adjustable (not installed, but in good working shape)
    C6Z 31mm Front Sway bar (car currently has stock C5Z bar installed)
    I'll throw in a set of old A6 Hoosiers (315/335's) that still have plenty tread but are likely heat cycled out, but could be fun for a track day.
    Full disclosure for those interested in this car for AS or SSR autocross, it currently has stainless steel brake lines and lowering bolts in the rear. I do have brand new stock brake lines (uninstalled) that I’ll include.
    Bottom line, firm price - $15,900
    Located in Austin, TX
    May be able to arrange for delivery to Nationals.
    More pictures in the local craigslist ad here:
    https://austin.craigslist.org/cto/6...09901.html
