Last Post 18 Oct 2017 10:02 PM by  speeddaddy
2-liter Ford S2 Pinto engine & complete Titan dry-sump system, and extra parts
speeddaddy
    Description
    2-liter Ford Pinto engine and dry-sump with adapter ring for Hewland transaxle. Has damaged piston so assemblies are available separately or together. Key items: Titan Dry Sump $1650; Ivey head Carb & intake $2200; adapter ring for Hewland $350; 2 liter Ford Short block rebuildable $700. Feel free to make offers.
    Details:
    ·        Complete Titan drysump system for 2.0 with steel pan, pulleys, brackets, bolts, mech tach drive & waterpump $1650 (New $2000+).
    ·        Engine 2.0 Liter Pinto: short block has one burned piston, minor aluminum deposit on cylinder but, can be cleaned up and rebuilt, you decide.  $700.
    ·        Ivey prepared cylinder head is great shape, undamaged, with intake and carb $2200 (new $2900).
    ·        Distributor Bosch - points style, $100.
    ·        Adapter ring for Hewland trans $400 ($599 new).
    EXTRAS:
    ·        2-liter block unprepped $350;
    ·        Cylinder head complete stk. $500 ($599 empty); cam oiling tube $35; intake $160; crank $250.
    ·        Stock-style flywheel w/110 tooth ring-gear & starter, and stock style clutch with "Bat2000" solid-hub alloy disc $450;
    ·        Tach drive (mechanical) attaches to pump $150 ($319 new);
    ·        extra cam followers; pivots & nuts; return springs;
    ·        fuel pump adjustable location $50;
    ·        new water pump $100;
    ·        complete "swoop down" exhaust headers $350 exit height of gearbox;
    ·        Supertrapp muffler 9"x 2"ID inlet 4" outlet $100.
    ·        2 sets PFC Brake Pad, 4 Piston Sports2/FC LD65 rear, old 83 Compound similar to 13 $65 each.
    So, if all bought new from Pegasus may cost $10,000+.  I will sell it together or in pieces. Shipping is extra. With elbow grease you can have a great race engine and spares. Tom Best 313-407-6232
    G-Loc Button
