Last Post 30 Nov 2017 09:54 AM by  Camaro67racer
2010 Mazda MX-5 Miata SCCA T4 Race Car Package
Camaro67racer
    2010 Mazda MX-5 (NC2) built to SCCA Touring 4 (T4) specs
    Car has many SCCA Majors podiums, including wins. It just finished 5th place of 40 cars at the 2017 Indy Runoffs. It was the highest finishing MX-5 and also turned the fastest lap time during the race of all the MX-5s. Current SCCA logbook and annual tech through April 2018.
    Built into a race car with just over 18K on the clock for the 2015 season. Built from a totally straight donor, was not crashed (this was NOT an old Cup Car).
    Car was shipped to Sean Hedrick at MiataCage who built a beautiful, roomy, strong roll cage. If you look on the MiataCage website under the SM5/T4 cage, the black car pictured is this car. Cage and interior are all professionally painted. Also includes custom rear bulkhead with access to fuel pump.
    Fresh cylinder head with all-new valves, springs, seals, VVT actuator, done by X-Factor Racing
    Custom MotoEast ECU tune
    T4 approved MX-5 suspension kit - MX-5 Cup (Eibach) springs (custom machined collars), anti-roll bars, and adjustable end links
    Bilstein shocks
    East Street Racing (Jim Drago) built 6-speed transmission
    Mazda OEM removable hard top with custom hard-fastened brackets
    Factory limited-slip differential
    Ron Davis aluminum radiator
    SafeCraft seat belts good for the 2018 season
    Custom driver seat base - attaches to factory seat mounts. Mounts could be removed to get driver lower if desired. I'm about 6ft tall and have lots of room.
    Custom seat slider (currently not installed, but included in the sale. MiataCage custom fabricating for potential enduro purposes.)
    SafeCraft three-nozzle fire suppression system
    MX-5 Cup cold air intake
    Catalytic converter removed from exhaust manifold and replaced with a straight tube (per T4 rules)
    Mazdaspeed MX-5 Cup exhaust
    Full Mazdaspeed / AWR brake cooling kit (including wheel-side ducts)
    Goodridge Stainless Steel Brake Lines
    G-Loc brake pads with one race on the fronts, tons of life remaining on the rear pads
    Rear wheel bearings and hubs were replaced with Mazda OE parts in June 2017. Only two weekends, plus Runoffs on them.
    Upgraded RX-8 front hub/bearings (allowed by T4 rules). Left front hub has two weekends, plus Runoffs on it. Right front has one additional weekend on it.
    Sparco steering wheel with NRG quick release
    CoolShirt cooler and hose included in the sale
    Advanced Autosports fuel sample port
    Custom ballast system makes changing weight very simple
    Longacre panoramic rear mirror, electric side mirrors w/factory switch
    Redline synthetic oil used in the engine, transmission (MTL), and differential
    Comes with three full sets of 17-inch wheels, including never-raced Hoosier H2O rain tires, Hoosier R7 with two heat-cycles, Hoosier A7 with four heat-cycles. One additional set of A7s with four heat-cycles (not on rims). Each set includes one heat-cycle that was a "scrub" session per Hoosier guidelines. Probably have more Hoosiers that would be good practice tires if buyer wants them.
    Three additional wheels will come with it (found a very small crack in one rim just before Runoffs, so this is not a complete set)
    One year old battery that sits on a Battery Tender when not in use
    The car is very light - 2,750 was the minimum weight with the suspension package on the car. With a 210 pound driver, it has over 170 lbs of ballast in the passenger side and ran with minimum of 4 gallons of fuel.
    Overall body condition is good. She does have a slightly dented left front fender, front and rear bumper covers have some wounds, but all pieces to make the car perfect are included with the sale. The passenger side of the car is in perfect shape. All of the graphics and stickers are in vinyl and removable.
    Car cover included
    Car will not come with a transponder or seat, but otherwise it is race-ready.
    Spares:
    Brand new Mazda front and rear bumper covers ($850 in parts), need to be painted
    Front driver fender - painted Brilliant Black to match car
    Driver door, gutted and painted Brilliant Black to match car
    Original cylinder head - also makes great power
    Used set of front G-Loc pads (plenty of life, but wanted a fresh set for Runoffs race)
    Box of spare suspension and hub assemblies - (lower front A-arms, rear arms, complete rear hub assemblies)
    Spare rear half-shafts
    Spare front brake calipers (including Mazda OE seals to be rebuilt)
    Bilstein SM5 springs (softer, these are also now approved for T4)
    $29,700 Located near Ann Arbor, MI
    Please contact me for more photos and info.
    Available at additional cost:
    Spare transmission, original trans that came with the car (18K on it) that has been torn down, gone through, and ready to go in the car. This is the stronger, upgraded transmission in the NC2 cars.
