Last Post 30 Jan 2018 02:06 AM by  Derek
FS: 1980 Crossle 40F C-Mod
    Ready to run
    Last run at 2017 Packwood SCCA Solo ChampTour event
    Extremely easy to drive and very forgiving
    0.05 seconds off the Track Record at Mission Raceway Park for FF (Rick Payne)
    Engine is very strong
    Chassis #40F-80-04
    This car is complete and ready to race.
    Log books from 2008
    History:
    Chassis is light at 850lbs without fuel
    Driver Fitment:
    Quite possibly one of the largest fitting cars around.
    Easily fits 230lb 6ft 3 driver
    CHASSIS
    Powder coated chassis is straight
    Rebuilt and braced custom Pedals
    SUSPENSION;
    Currently installed wide track 45F suspension
    Complete narrow track 40F suspension included and axles
    All suspension bolts are safety wire drilled
    AN braided stainless oil lines
    Penske shocks, rebuilt by Porter Racing.
    New rear left lower wishbone
    New rear wheel bearings
    New cv joints
    2 front swaybars included
    ENGINE;
    Loyning Engine with aluminum head., build sheet and receipts total over 6000$ (crank,pistons)
    Dyno included
    Approx 4 hours on it.
    Newly machined starter plate with
    New Gaskets (Oil pan, front crack seal, valve cover gasket)
    Tilton clutch
    Only run redline fluids
    TRANSAXLE
    Hewland MK 9 9:31 shifts very smooth
    Rebushed hockey stick
    New thrust washers
    ELECTRICAL;
    2 Odyssey pc680 batteries
    Redone electrical
    Bosch coil & a New Pertronix Flame-Thrower II Epoxy-Filled Ignition Coil (Not installed yet) https://www.pegasusautoracing.com/productdetails.asp?RecID=9810
    New distributor (Pertronix FlameThrower High Performance Distributor (Not installed yet) https://www.pegasusautoracing.com/productdetails.asp?RecID=9670
    New electric rad fan with switch
    New rev limiter (MicroDynamics DRL 3 Digital Rev Limiter) https://www.pegasusautoracing.com/productdetails.asp?RecID=3178
    BRAKES & CLUTCH;
    LD19 Calipers
    Fresh AN braided stainless brake and clutch lines
    New Wilwood brake master cylinder
    Many sets of various pad compounds
    Miscellaneous;
    New Front skid block
    OMP seat belts
    2 sets of Panasports in gold
    New fuel cell foam
    New fuel pick up screen
    New inline fuel filter 5 Micron
    New fuel line
    Special tool: Head bolt shocket
    Spare nose cone
    Spare aluminum radiator
    PRICE $13000 USD
    Contact: Derek 604 600 0844, derek128@gmail.com
    Vancouver,BC,Canada
    Optional
    Coast fab muffler
    1337 integrated 1st Gear and Layshaft
    Double Axles Open trailer 7000lbs
    pic: https://drive.google.com/drive/folders/0B7T4rSf7QkUgN1RZdm1WdUJyeGM?usp=sharing
