Last Post 20 Feb 2018 09:06 PM by  kayakanimal
1965 Zink Formula Vee setup for Autocross
kayakanimal
    For Sale: $8000 Located between New Orleans and Baton Rouge LA
    Not looking for trades
    Motor rebuilt 6/2017 and maxed out for C MOD class.
    It includes:
    Approx. 130hp. Car is 950lbs
    1915 CC
    39mm intake and 32mm exhaust valves
    Ported and polished head with cross hatched intake
    44 IDF Webber carb
    Dual valve springs with 3 angle valve job
    BIG cam.
    Custom exhaust with adjustable Supertrapp Diffuser
    Counterweighted welded German steel crank
    Racing pistons and rods
    All balanced to less than 1 gram
    MSD Electronic ignition with rev limiter
    Purchased 6/2017 racing clutch and pressure plate
    Daiken Solid Center 200mm clutch disk, semi metallic
    Oversized oil pump
    Current with a "sit up" seat. I am 6' 4" 240lbs and fit fine
    I still have the "laydown seat" for "normal" size people
    VERY wide cockpit
    Adjustable foot pedals
    Seatbelts purchased 6/2017
    Adjustable coil over shocks on each corner.
    The car has been weighted to 52% front and 48% rear with me in it 240lbs
    10" rear and 9" front Hoosier 25b Racing slicks. Purchased 6/2017. Still VERY sticky
    4 7" Hoosier Rain "slicks" (mounted on rims) that have never been used (Purchased 6/2017) and kept in climate control.
    Brake proportioning valve
    I replaced both Wilwood master cylinders and all 4 brake slaves
    Double steering extender...make turning the wheels (when steering) MUCH faster
    Drum brakes. Drums in front replaced 6/2017
    I still have ½ case of the racing oil the motor builder recommended
    PENN-Grade 1 Partial Synthetic Motor Oil SAE 20W-50
    +2.5 quart deep sump oil pan
    Custom dual cooling fans for motor. Everything runs off battery
    Optima Red Top battery
    I run it on 1 gal Sunoco 110 octane racing fuel to 4 gallons of 94 non ethanol. I have some left
    Extended roll bar
    I have got LOTS of FTD (Fastest Time of the Day) racing autocross. Almost always top 3 or better
    Selling because I am getting a bit old and having trouble getting in and out because of my bad back.
    This car is scary fast! It needs NOTHING to race and beat about everything out there
    I will include my Gopro MOUNT (Gopro NOT included) to mount YOUR camera to the roll bar
    Here is a link to my YouTube page to see lots of videos of me racing.
    https://www.youtube.com/channel/UCboiDJw-JKegWNjEHz10yFw
    https://batonrouge.craigslist.org/cto/d/1965-zink-formula-vee-built/6503509120.html
