Last Post 11 Jan 2019 05:59 PM by  bbimpreza
2010 Hyundai Genesis Coupe 2.0T Race Prepared
bbimpreza
25 Aug 2018 01:12 PM
    I am looking to sell a Hyundai Genesis Coupe 2.0T that is race prepared. I purchased the vehicle new in March 2009 with the intent of building it for Time Attack. I have not been able to fully utilize it over the years (20-30 track days total), and it deserves to go to a home where it will be used. It is a turn-key vehicle, ready to go racing or for DE events. I am asking $23,500 OBO. An extensive spares package will be included with purchase. Please let me know if you have any questions. Thanks!
    2010 Hyundai Genesis Coupe 2.0T Base
    Tsukuba Red
    6-Speed Manual
    Located in Austin, TX
    ~4000 miles on chassis and motor
    Clean Title In-Hand
    Pictures
    https://www.flickr.com/gp/59192022@N02/Xs4art
    https://flic.kr/s/aHsjEjDYXx
    Engine
    Poweraxel Reflash making ~290 WHP and ~290 WTQ. I no longer have the Poweraxel flasher that was on the car as it was stolen, but I do have another programmer that can be used to flash the car
    MODE Racing Intake
    MODE Racing 3” Downpipe, Midpipe and Cat-back
    MODE Racing 2.5” Intercooler Piping and FMIC (24”x7.9”x3.5”)
    MODE Racing Engine Oil Cooler (Mocal Thermostatic Sandwich Plate, Mocal 25 Row 235 Matrix Core, -10 AN Lines)
    MODE Racing Lightweight Battery Holder with Odyssey 680 Battery
    Air/Oil Vapor Separator PCV System Oil Catch Can
    Custom Built Race Radiator
    MODE Racing Radiator Hoses
    Walbro 255 LPH Fuel Pump
    Suspension/Drivetrain
    JRZ 3-Way Adjustable Race Coilovers with Remote Reservoirs and Billet Top Hat
    Rear Suspension has been converted to a Coilover setup from separate spring and shock
    Cusco 1.5 way Rear Differential
    COBB Shift Knob
    MXP Front Sub-frame Brace
    MXP Rear Sub-frame Braces
    MXP Rear Interior Brace
    Brakes/Wheels
    Stoptech 6-Pot Front/4-Pot Rear Big Brake Kit (Red)
    ARP Wheel Studs
    4x Enkei NT03+m, 18x9.5, +27mm, White, Front Wheels
    4x Enkei NT03+m, 18x10.5, +30mm, White, Rear Wheels
    4x Toyo R888, 255/40/R18 Front Tires
    2x Toyo R888, 285/30/R18 Rear Tires
    2x Toyo R888, 295/30/R18 Rear Tires
    Exterior
    APR Performance 61” GTC-300 Rear Wing
    APR Performance Side Rocker Extensions
    Seibon SC Style Carbon Hood
    Seibon Carbon Trunk
    Interior
    Custom Driver and Passenger Seat Rails with Sparco Sliders
    Sparco Pro 2000 Carbon Driver and Passenger Seats
    Custom Built Rollcage with the A & B Pillars Tied to the Cage - built by Brian Lock and CJ Wilson Racing
    Driver’s Window Net
    Right Side Interior Net
    Battery Kill Switch
    Safecraft Fire Suppression System
    Rapfix 2 Steering Wheel Hub
    Sparco Steering Wheel
    Splash Short Steering Wheel Hub
    Schroth Racing Clubman 3 6-Point Harnesses
    MODE Racing 3-Gauge Pod
    Autometer Gauges
    AEM UEGO
    Here is a link to an article MotoIQ did on the car prior to its current configuration,
    https://motoiq.com/in-the-beginning/
    The extensive spare package includes the following (I am sure that I am missing something):
    Engine Parts
    Poweraxel Tuning Software
    New ATP Turbo 3076R for Hyundai Genesis Coupe 2.0T
    New ATP Fuel Return Fitting
    3.8L V6 Long Block Disassembled -Missing Fuel Rail
    2.0L Turbo 4-cyl Long Block Disassembled
    Cylinder Head has been completely rebuilt
    Ported and Polished
    GSC S2 cams, 272 Intake and 270 Exhaust
    Ferrea Components
    Spare 2.0L Turbo engine wiring harness
    Spare 2.0L Engine Harness w/ fuse box
    New 2.0L Piston
    New Head Gaskets
    New Oil Filter Bracket Gasket
    Stock Cat-back
    Drivetrain Parts
    6-speed Transmission Internals
    6-speed Transmission Rear Case
    Shifter Linkage with Shifter
    2.0L Partial Driveshaft
    3.8L Partial Driveshaft
    Stock Rear Differential Pumpkin
    Rear Differential Cover
    3.727 Ring and Pinion
    3.538 Ring and Pinion
    Stock LSD Disassembled
    New Wheel Bearing
    New Qty. 2 Rear Differential Bearings
    Non-LSD Rear Differential
    Exterior/Interior Parts
    Seibon Carbon Grill
    New Hyundai Dash Pad
    New Hyundai Info Surround
    New Hyundai Info Top
    New Hyundai Black R-Spec Center Face
    Qty. 2 Extra JRZ Adjustment Caps
    Remaining Stock Parts from my car
    Spare Tire
    Speakers
    Seat Belts
    Floor Mats
    Stock Wheels/Tires
    Interior Pieces
    Etc.
    Please let me know if you have any additional questions. It is best to email me at, billy at moderacing.com. Thanks!
    Billy Brooks
    bbimpreza
    New Year! Let's try again.
