Last Post 24 Nov 2018 01:36 AM by  dkmura
T2 Shock Aborber Clarification
DanHuberty
10 Sep 2018 08:10 PM
    When reading the T2 rules for shock absorbers in T2 it states that "The make of the shock absorber may be changed". Does this mean that I can change the OEM shocks to another brand such as MCS, Ohlins, or other? As an example if I have a BMW M235iR that has KW shocks on it from the factory can I change them to MSC or Ohlins triple adjustable shocks?
    Dan
    dkmura
    Dan- in most cases, the answer would be yes; you can change the manufacturer and model of the dampers you use. However, with your BMW M235iR, I believe the spec line says you must race that model as it was originally spec'd. Check with SCCA National to doublecheck this.
