Last Post 18 Sep 2018 09:31 AM by  AaronH
How to register for duel drivers?
TimMan
17 Sep 2018 08:44 PM
    Be gentle..
    Just bought a  Miata.. Tired of autocrossing a Fit... want to run on the 30th with my son.. not sure how to register as duel driver car.. we'll both need waivers... will both join SCCA next year...
    AaronH
    On MotorsportReg, you will both need to register and select the "Weekend membership". You will sign the waivers when you get on site for the event. You will need to register in the same class, but with different numbers and the easiest way is to just add a "1" in front of your number. For example, you should register as 85 and your son as 185. You will need to change the number on the car during your runs as you change drivers (adding/removing a strip of tape is common).
    Here is the link to the Event #8 registration: https://www.motorsportreg.com/events/2018-stl-solo-points-event-8-family-arena-scca-st-louis-540930
