No rear KYB AGX for 88 CRX?
Last Post 28 Aug 2010 07:57 PM by Shinny. 5 Replies.
PrevPrev NextNext
ShinnyUser is Offline
27 Aug 2010 11:01 PM
    Haven't been able to find them I know there's some difference in the lower control arms on the 88s. I'm wanting the AGX so I can auto and rally cross this car. Anyone know if I'm wrong or have another strut for the same price range thats that adjustable?
    Kerry CoughlinUser is Offline
    28 Aug 2010 06:44 AM
    Check the rule book but I from what I can remember since control arms are open you should be able to use the 89-91 rear LCA's. Or if you cannot be the part new from honda and its been superseded.
    But don't quote me.
    Kerry
    28 Aug 2010 02:36 PM
    But don't quote me.
    Kerry
    Did a quick search when I found out about the difference. From the 2009 classing chart I looked at control arms were not allowed to be replaced or modified in STS
    G. JayUser is Offline
    28 Aug 2010 05:37 PM
    SCCA 2010 Solo Rules section 14.8.I.1:
    I. Camber kits, also known as camber compensators, may be installed.
    These kits consist of either adjustable length arms or arm mounts
    that provide a lateral adjustment to the effective length of a control
    arm. Alignment outside the factory specifi cations is allowed. The following
    restrictions apply:
    1. On double/unequal arm (e.g. wishbone, multi-link) suspensions,
    only the upper arms OR lower arms may be modifi ed or replaced,
    but not both. Non-integral longitudinal arms that primarily control
    fore/aft wheel movement (e.g. trailing arm(s) or link(s) of a multilink
    suspension) may not be replaced, changed, or modifi ed.
    StreetTireStockUser is Offline
    28 Aug 2010 06:46 PM
    The 1988 Honda CRX had the same rear shock as the '98+ Integra Type-R. They bolt right on. So any Koni, Bilstein, etc for the Type-R will fit in the rear. Crazy, you say? My first autocross car was an '88 CRX I ran in CSP. I had AGX's up front, but there were none available in the rear. Bilstein had some for the ITR, bolted right up. Problem solved.
    Thx muchly lol that helps a lot!
    Woodhouse Motorsports CarboTech 88x31 Button
    Sampson Racing Vorshlag 88x31 Button
    Race-Technology Traqmate 88x31 Button
    grassrootsmotorsports Honda Superstore 88x31 Button
    stockyard miata MLS 88x31 Button
    HoosierTire88x31 Hyperfuels 88x31 Button
    Club Radio 88x31 Sunoco 88x31 Button
    JarrettMustang Holliday Canopies 88x31 Button
    Evolution Performance 88x31 Button
    RBJ App saferacer
    fat cat
    SPS 88x31 Button
