GrassRootsMotorsports
CM Cars For Sale...
Last Post 09 Feb 2012 10:49 PM by Markwrx. 169 Replies.
PrevPrev NextNext
Page 1 of 912345 > >>
pruUser is Offline
31 Aug 2010 05:16 AM
    Via ApexSpeed FF Classified Section
    84 RF84 Vandiemen Formula Ford : KY / Currently configured for Solo / $6,700 ($9,500 with enclosed trailer)
    1981 Dulon MP21 : ID / Currently configured for Solo / $10,000 (includes enclosed trailer)
    Van Diemen RF84 : CA / Recent ground-up restoration / $6,500
    PCalhounUser is Offline
    03 Sep 2010 02:14 PM
    Is the sale didn't go thru, this car is a good deal and will ultimately be a more competitve car than an 84 VD.
    http://www.apexspeed.com/forums/sho...hp?t=40298" target="_blank" rel="nofollow">http://www.apexspeed.com/forums/sho...hp?t=40298
    http://www.apexspeed.com/forums/sho...hp?t=40298" target="_blank" rel="nofollow">http://www.apexspeed.com/forums/sho...hp?t=40298" mce_href="http://www.apexspeed.com/forums/sho...hp?t=40298" target="_blank" rel="nofollow">http://www.apexspeed.com/forums/sho...hp?t=40298">
    pruUser is Offline
    03 Sep 2010 03:21 PM
    Pete,
    Sale pending on the RF-85. Nearly certain that it will end up in Indy...[;)]
    pruUser is Offline
    08 Sep 2010 05:31 AM
    Van Diemen RF85 for Sale : WI / Fresh powder coated frame / $10,000 ($11,000 with open trailer)
    DickRUser is Offline
    08 Sep 2010 06:06 AM
    Pru,
    You beat me to it. Looks a lot better than mine!
    Excellent CM car in my obviously biased opinion! Probably just needs an integral first gear and fresh 25B's to be READY to clean up in autoxcrosses!
    Dick
    CM 85
    85 VD
    14 Sep 2010 10:54 AM
    Still for sale:
    http://www.apexspeed.com/forums/sho...hp?t=41764
    Not mine.
    Dick
    85 VD RF-85
    CM 85
    GChambersUser is Offline
    16 Sep 2010 07:32 AM
    Pete,
    Yep, Nick Myers bought it. Mark Lamm has been tinkering with it all week. It should have it's first event this weekend.
    That 85 in Wisconsin has me all hot and bothered! I need to get my Miata sold fast!
    LockedUser is Offline
    16 Sep 2010 08:04 AM
    [:D]
    16 Sep 2010 08:49 AM
    Great if we can get three 85 VD's to show up at Nationals! I'm shooting for 2012 after I hopefully either retire or have more vacation (2 weeks total sucks compared to the 4 or 5 I had at my previous job.)
    FYI, how did Don Elzinga pull off a second place in a single driver car?
    Dick (usually single driver . . . I take the "solo" part of "solo" literally [:D] )
    85 VD
    CM85
    pruUser is Offline
    19 Nov 2010 08:43 AM
    1985 Reynard FF : DE / includes open trailer / $6500
    barryottUser is Offline
    19 Nov 2010 12:07 PM
    Tyson Sawyer was a perennial front runner in his '85 Reynard, and Daddio won Nationals when he drove it. Cheap too! I remember Tyson saying he ended up welding the floor pan on his to keep it attached and help with stiffening the chassis....
    Barry
    t walgamuthUser is Offline
    22 Nov 2010 09:45 AM
    I am thinking about that 85 Reynard. I went down to Indy on Sunday and tried Geoff's Vandieman on for size and found it a challange to get in and out of and to push pedals one at a time. After reading some on Apex I think these are solvable problems. Can any body comment on the width and foot room in the 85 Reynard compared to the 84 Vandieman?
    pruUser is Offline
    22 Nov 2010 11:13 AM
    t walgamuth wrote:
    I am thinking about that 85 Reynard...Can any body comment on the width and foot room in the 85 Reynard compared to the 84 Vandieman?
    I never sat in a '84 Van Dieman, but I did own a '85 Reynard (the aforementioned Sawyer/Daddio car). That said, I believe what you find is, outside of the Swift, most of the FF/CM chassis of that era have roughly the same size footbox. That is, the footbox size of the '84 Van Dieman and '85 Reynard should be very close.
    Question: what type of shoes (if any) were you using while trying out Geoff's car? The footbox size of nearly all FF/CM chassis dictates that drivers use very tight fitting shoes (drivers, wrestling, etc.) to properly work the pedals as well as get in/out of the car. When someone not wearing this type of footwear tests the fit of my Swift, I tell them that they best remove their shoes if they really want to properly fit let alone get in/out.
    22 Nov 2010 11:38 AM
    22 Nov 2010 11:40 AM
    I have a no shoe rule for anyone stepping foot in my car. Same with no food, or drink. [:D]
    22 Nov 2010 12:42 PM
    Tom, like I told you last night, those shoes would make a big difference. Also, my car is tighter to get into than any of the other cars I've sat in. Try a few out. Don't rush into anything. I'm guessing you'll find one that fits if you look long enough.
    22 Nov 2010 02:39 PM
    Geoff, thanks very much for your generous sharing of your car last night.
    I can see you are going to be having some real fun with it next year!
    Tom
    22 Nov 2010 05:04 PM
    As noted footwear makes a difference, as does sitting in the car w/ your belt on, wallet in your pocket, or wearing a sweatshirt Yes, they are a tight fit, but once you have a seat made to your proportions, adjust the pedals & steering column a lot of folks can be made to fit and be much more comfortable.
    What size shoe do you wear? If it is under 12 you should not have a problem.
    22 Nov 2010 07:52 PM
    Tom,
    I forgot to mention in the emails last night that the pedal pads themselves may be the "issue". When I had pads with longer bolts made I also carefully determined the pad width and "offset" to minimize foot overlap without having the pads too far apart. Note the "flag look" of the brake pedal in the picture I sent you. One of the benefits of Mod compared to stock based class rules. Minor hassles compared to the fun factor!
    By the way, there is no room for a dead pedal in my car. I do have a heel rest but I don't think I ever use it.
    Dick
    22 Nov 2010 11:39 PM
    Yes, I was reflecting today that if I don't like the pedals I can change them unlike in a stock class!;)
    Dick, thanks for your help!
    Woodhouse Motorsports CarboTech 88x31 Button
    Sampson Racing Vorshlag 88x31 Button
    Race-Technology Traqmate 88x31 Button
    grassrootsmotorsports Honda Superstore 88x31 Button
    stockyard miata MLS 88x31 Button
    HoosierTire88x31 Hyperfuels 88x31 Button
    Club Radio 88x31 Sunoco 88x31 Button
    JarrettMustang Holliday Canopies 88x31 Button
    Evolution Performance 88x31 Button
    RBJ App saferacer
    fat cat
    SPS 88x31 Button
