1982 Morton Solo Vee - price reduced!!
Last post 04-13-2007, 7:46 PM by mr20turbo. 8 replies.
  •  03-12-2007, 1:27 PM 236423
    Will fit large driver (6' 2", 200 lbs) and completely sorted out.
    838 lbs.
    Less than 3.5 hours since engine rebuild, well prepped.
    Zero roll with Carreras all around.
    History since new, logbooked until a few years ago.
    Always garaged, ran in it last year so it hasn't just been sitting.
    Located in Kansas
    $6200.00  $6,000  (edit:  see below post for more detail)
    Includes car, trailer, ten years worth of spares and parts, multiple
    sets of tires and wheels, specialty tools, etc. Pretty much a turn-key
    deal - put on your helmet and drive.
    No dedicated website but email me if you're interested for specs,
    pictures, etc. at dgeis at cox dot net
    Dave Geis
    #25 ss - '07 Z-51
    http://wichitascca.org
  •  03-12-2007, 2:44 PM 236438 in reply to 236423
    Re: 1982 Morton Solo Vee
    You should also post this on the classified ad forum at formulavee.org/interchange
  •  04-02-2007, 9:16 AM 239289 in reply to 236438
    PRICE REDUCED to $6000!!!
    So what are you getting for that reduced price?
    McNamara “clone”, cockpit widened for larger driver (I’m 6’2”, 200 lbs)
    Original Logbooks and history since new.
    838 lbs
    Always garaged
    Zero roll rear suspension
    Carrera adjustable shocks
    ¾” front sway bar
    ½” adjustable rear sway bar
    Steering quickened
    Belts dated Apr 03, Fuel cell replaced 2-01, new battery 8-05
    Engine
    1600 cc
    Rebuilt Spring 2002, time on engine since rebuild: 3 hr 40 min
    New Weber 40IDF installed 5-03
    Tires and Wheels
    1 set mounted Goodyear R120 on Diamond Racing wheels
    1 set mounted Hoosier R25A on Diamond Racing wheels
    1 set unmounted “new” Hoosier R25A w/3 laps at HPT
    1 set mounted Goodyear FV rain tires on VW wheels
    1 set mounted Goodyear FV rain tires on VW wheels (junk for storage)
    1 set spare VW wheels
    Trailer
    1997 PJ Trailers, 6 ½’ x 10’ utility trailer, 5000 lb axle
    New tires 9-02
    Chrome wheels
    New LED lighting
    Custom U-channel aluminum ramps
    4x 10,000 lb tiedowns
    Spare tire
    Decking replaced 8-00
    Cover for winter storage
    Spares
    1x Engine block
    1x IRS transaxle
    1x complete exhaust system
    7/16” rear sway bar
    9/16” front sway bar
    Engine stand
    3x large boxes of misc. parts
    1x large tool box full of everything from 36mm axle nut socket to extra carb jets
    4x scales
    2x car stands
    Tire balancer w/wide 5 adaptor and weights
    2x gas cans
    Trickle charger w/quick connect
    Misc. VW service manuals & catalogs
    Alignment “toe” bar
    Longacre 0-30 tire guage
    Seat pad for shorter driver
    Foam pad for taller driver
    _________________
    Dave Geis
    #25 SS - '07 Z-51
    Dave Geis
    #25 ss - '07 Z-51
  •  04-02-2007, 11:29 AM 239307 in reply to 239289
    When you say it'll fit a large driver, how large? :)
    I am Chris Hammond.
    Going2Colorado.com
  •  04-03-2007, 10:07 AM 239416 in reply to 239307
    where's the car located?
  •  04-03-2007, 1:03 PM 239450 in reply to 239416
    Wichita, Kansas.
  •  04-03-2007, 6:10 PM 239492 in reply to 239450
    Sorry for the delay in response. I couldn't log in and had to have a computer ner. . . . ahhhh. . .a good friend come over and see what was wrong ;-).
    In answer to the questions asked. 6' 2" and 200 lbs is pretty much it. Anything more than that will be above the main-to-front hoop "ruler" check. It's actually quite a bit more than the "normal" formula car.
    And already answered, it's in Wichita Ks.
    Dave Geis
    #25 ss - '07 Z-51
  •  04-03-2007, 9:08 PM 239510 in reply to 239492
    Dave G:
    ...Anything more than that will be above the main-to-front hoop "ruler" check.
    That's the rule in club racing.  For Solo, the pertinent rule is in Appendix C - SOLO ROLL BAR STANDARDS
    A. BASIC DESIGN CONSIDERATIONS
          2. The top of the roll bar shall not be below the top of the
    driver’s helmet when the driver is in normal driving position,
    and shall not be more than six inches behind the driver. It is
    strongly suggested that the roll bar extend at least three
    inches above the driver’s helmet. In case of two driver cars,
    both drivers must be within the roll bar height requirement,
    however only one driver must be within six inches of the roll
    bar. In a closed car equipped with a roll bar/cage, it must be
    as close as possible to the interior top of the car.
  •  04-13-2007, 7:46 PM 240627 in reply to 239510
    i know it is a long shot, but you wouldn't be interested in a trade for a fourwheeler by chance would you? I have a 2006 yfz 450 i am currently in the process of selling. let me know if it is something you would entertain.
