New Cobalt SS in DS? If so, does it have a chance?
Last post 08-20-2008, 1:06 AM by mwood. 140 replies.
05-21-2008, 2:31 AM |
Fastmike
Joined on 12-16-2001
Seattle Wa USA
Posts 1,654
Points 22,670
18 x 7.5's.
160mph top end.
Nurburgring in 8:22
"No lift" shifting to maintain boost.
GXP motor.
Brembo's
Don't know about camber/FSM/crash bolts stuff yet..
OH!
$23.5K w/lsd
Should be at dealers anytime now.
Thoughts?
FM
05-21-2008, 2:47 AM |
Vanimaniac
Joined on 04-09-2003
Golden, CO (USA)
Posts 177
Points 1,925
Re: New Cobalt SS in DS? If so, does it have a chance?
I was wondering the same thing. Looks pretty good on paper. Looks horrible in person. :) Van
  1986 Trueno GT-S (DSP), 1989 Honda Civic Si (HS) Autocrossing on the cheap.
05-21-2008, 3:04 AM |
Fastmike
Seattle Wa USA
Posts 1,654
Points 22,670
HAHA! I look horrible in person too but I go ok.
I wonder abouut camber and tire clearance.
I am excited to drive one. I am surprised that a LSD is an "option". It should be standard on that car.
05-21-2008, 8:30 AM |
BrianGT
Joined on 09-16-2005
Posts 207
Points 3,175
Could just be another SRT-4, and have trouble turning and putting down power. I wonder if GM performance will come out with some sort of GXP package for it to address it's potential shortcomings? -Brian
89/189 STS/STX '89 Civic Si
05-21-2008, 9:27 AM |
Fastmike
Seattle Wa USA
Posts 1,654
Points 22,670
I guess it all depends on the LSD and how effective it is.
If it can turn but not burn, then it might have a chance.
FM
05-21-2008, 10:04 AM |
Vanimaniac
Golden, CO (USA)
Posts 177
Points 1,925
Edmunds gave it a good overall review....
http://www.edmunds.com/apps/vdpcontainers/do/vdp/articleId=125288/pageNumber=1?synpartner=edmunds&pageurl=www.edmunds.com/new/2008/chevrolet/cobalt/100919271/roadtestarticle.html&articleId=125288 Van
05-21-2008, 10:29 AM |
mattm
Joined on 02-01-2004
Westport, Connecticut
Posts 1,152
Points 11,345
Fastmike: Thoughts? FM
It should do well..... if no else enters the class.
Matt Murray I am perfectly capable of learning from my mistakes. I will surely learn a great deal today.
05-21-2008, 11:15 AM |
John V
Joined on 01-12-2004
Columbia, MD
Posts 765
Points 9,215
Seems similar in specs to the Mazdaspeed 3... lots of power with narrow wheels. I'm surprised that more people aren't trying the mazdaspeed 3. Mazda has good contingency money.
The Cobalt SS is a couple hundred pounds lighter than the mazdaspeed 3 though.
John Vitamvas Overweight, one-wheel drive tire-eater
05-21-2008, 1:47 PM |
01 FS Z28
Joined on 01-01-2001
Brookville, PA
Posts 545
Points 8,315
It remains to be seen just how "good" the 135i will be in DS. I think the lack of a diff will not be a good thing, and have heard reports that the "e-diff" thing kind of works, but also that it cooked the brakes in short order--on street tires. That will only get worse on R-comps.
I'm not sure the old Cobalt with a diff isn't a good DS car to be honest. I've only driven open diff cars, but they handled quite well. I can't see how more power would be bad if the diff works at all. At the very least it's driving 2 tires vs. one in the 135i, weighs a lot less and we know the BMW won't have much if any camber. The Chevy likely won't have much either, but could have some.
Sam Strano Owner--Strano Performance Parts 800-729-1831
05-21-2008, 3:05 PM |
Gunny JC
Joined on 02-05-2005
Eastern Tennessee
Posts 113
Points 1,030
Not positive they are the same, but the Saturn ION Redline has the option of a LSD as well and they are basically the same car. The LSD is a quaife.
STS class '96 Saturn SC-2
05-21-2008, 3:47 PM |
gary p
Joined on 11-23-2001
Monticello, IL, USA
Posts 2,214
Points 35,570
01 FS Z28:
FWIW, the ION Redline FSM allowed "slotting" the front struts to a defined limit for camber adjustment. Supposedly you could get almost 2* negative. Would be surprised if the 'balt SS Turbo was different.
05-21-2008, 10:13 PM |
Fastmike
Seattle Wa USA
Posts 1,654
Points 22,670
The more I think about this car, the more I am talking myself into it.
Probably should buy 2 of them...A white one and a black one. That seems to be the most effective method....LOL!
DS beware! Fair warning!
FM(ZOK for sale?)
05-21-2008, 10:59 PM |
MilesJ
Joined on 09-17-2007
NC
Posts 18
Points 315
But Mike, where will you find Bilstein dampers for this car???? And from what I've heard the quaife diff is really good on the car. I just hope the general doesn't screw up the gearing.
BS RX8
05-21-2008, 11:10 PM |
Fastmike
Seattle Wa USA
Posts 1,654
Points 22,670
Here is quote my buddy found...
"The Cobalt chassis team discovered that the suspension worked better on the Nordschleife with somewhat less rebound control than initially estimated, but with firmer spring and stabilizer bar rates. The result is a reasonable ride out in the real world, with plenty of body-motion control for fast track or road work.
Still trying to find out more about the car but I am getting jazzed up. So far, I think it can get it done in DS with a good driver.
It sure get's it done at the Ring.. http://en.wikipedia.org/wiki/Nordschleife_fastest_lap_times
LOTS more research to do about autox stuff... I REALLY need know how fast in 2nd gear!!!
FM
05-22-2008, 12:12 AM |
Chiketkd
Joined on 08-23-2006
Charlottesville, VA
Posts 403
Points 3,540
Fastmike:I REALLY need know how fast in 2nd gear!!!
Mike,
Transmission | GM Powertrain Sweden F35 5-speed manual | Gear ratios: (:1): | | First: | 3.38 | Second: | 1.76 | Third: | 1.18 | Fourth: | 0.89 | Fifth: | 0.70 | Reverse: | 3.17 | Final drive ratio: | 3.82:1 |
So on the stock tires, with a 6,300rpm redline, top of 2nd gear is good to ~69-70mph.
Chike Dellimore - Blue Ridge/Washington DC Regions 2006 Galaxy Gray 6MT Mazda RX-8 (B-stock) Former 2006 Steel Gray 5spd WRX (D-stock) "Between now and Nats, f!ck seat time - I'm working on crazy!!!"
05-22-2008, 7:27 AM |
piknockout
Joined on 10-18-2005
Aberdeen, MD
Posts 189
Points 2,905
And FWIW, not that Sport Compact Car is the greatest resource, but they have called it possibly the best FWD car made, comparing it to the ITR. Had a lot of great things to say. If only I weren't so averse to buying American, no offense.
But the car does seem to have a lot of potential, especially if a TSB allows for more camber and the LSD can put the power down.
2003 Nissan Sentra SE-R Spec V Sponsored by AgileAuto.com D.C./Philly Region - 3 STXcardomain.com/id/piknockout
05-22-2008, 8:09 AM |
BrianGT
Posts 207
Points 3,175
Yeah, looks like 2nd tops out at 69mph on 245/35-18 tires, but it doesn't look that bad, since it has decent tq at 2k.
05-22-2008, 8:37 AM |
Darkhelmet
Joined on 10-04-2006
Plaid
Posts 129
Points 1,485
Well...
Since they are finaly getting to dealers' lots / showrooms now, I should be able to get a comparison between my non-LSD SC car, and a turbo model.
Everything I've been readin/hearing on the car has been super-positive. The people that liked the last car seem to think this is HUGE improvement and say the car is one of the best FWD Spo Coms to come out in a long time.
Where my car is just good in a striaght line and has decent stock brakes and good transitional qualities...they feel the car is great in all categories.
Really want to get one out on course to do a decent evaluation. Seeing as mine is one of a handful of STOCK SS's left out there.. and even fewer that autocross one.
Brian Huber 2006 Cobalt SS-Supercharged #58DS Official car of One-Wheel Drive Racing's 2008 Solo campaign... If you aint last, then you aren't driving this car.
Page 1 of 8 (141 items)
1 ...
