Rule change proposal from the July Fast Track?
Last post 06-03-2008, 1:04 PM by BrianChevy. 7 replies.
  •  05-22-2008, 3:10 PM 301773
    FastTrack - June:
    The previously published rule change proposal concerning motor mounts (ref. 08-166) will be recommended to the BOD by the SEB.
    I just saw this in the latest Fast Track and I am wondering when the rule change proposal took place? I was under the impression that this rule was added year or so ago and it was already in working. Now even though I have followed all of the Fast Tracks, I have never seen anything about this proposal for change.
    Anyone out there that can shed some light on this issue?
    Thanks!
    Fedja
    95 AWD #34 SM or ESP
    "Let boost be with you...
    ...and bring some timing too!"
    http://www.geocities.com/esp_er
  •  05-22-2008, 3:56 PM 301788 in reply to 301773
    Re: Rule change proposal from the July Fast Track?
    Maybe this is the one from the April FasTrack?
    http://scca.com/documents/Fastrack/08-fastrack-apr.pdf
    • The following rule change proposals have been recommended by the SPAC and are published for member comment:
    o Change 15.10.J to read:
    “15.10.J Engine mounts may be replaced, but must attach in the factory location(s) without additional modification or changes. Engine position may not be changed.
     Hydraulic shock type rear engine locators, or bobble struts may be replaced by manufacturer’s performance part, or aftermarket replacement part. This part must retain factory dimensions and attachment points, including factory design. (Example: If factory locator/bobble strut is gas or hydraulic piston type, replacement part must be gas or hydraulic piston type.)”
    STS2 - 1990 Mazda Miata
    Borrowing BS - RX-8
  •  05-22-2008, 5:23 PM 301803 in reply to 301788
    I believe so!
    Not sure why did I miss that one...
    Thanks!
    Fedja
  •  05-23-2008, 12:25 AM 301874 in reply to 301803
    So the upshot here is that we can use solid motor mounts in 2009?
  •  05-23-2008, 11:36 AM 301936 in reply to 301874
    That is what was removed from the original rule. It looks like someone important needed to fit his/her new engine in there the correct way so the rule got softened up! Smile
    Just to start one of the rumors maybe, this might allow some of the BSP cars to get help from stronger brothers...
    Fedja
  •  05-23-2008, 11:56 PM 302051 in reply to 301874
    How is this proposal much different from what we have today?  I read 15.10.J as currently allowing you to replace all the rubber in a mount with Delrin, PEEK, or any other hard plastic.  Is that really much different from a solid metal mount, as the proposal would allow?
  •  05-27-2008, 4:11 PM 302491 in reply to 302051
    The major difference is that amount of metal can be increased now which is something you couldn't do it before! That is what led me to believe that someone might need some extra allowance for their swap!! Smile
    Fedja
  •  06-03-2008, 1:04 PM 303673 in reply to 302491
    Gee, I sure wish that somebody important needed to swap in aftermarket radiator into SP.
     We are going to have to wait until 2009 to get some radiator sanity.
    Brian
    1987 Chevy IROC Z/28
    #68 ESP
    ARSCCA
