Anybody Autocrossing an Evo in AS?
Last post 06-26-2008, 4:02 PM by DaveH. 7 replies.
  •  06-16-2008, 4:57 PM 305622
    ..just checking and would like to have some feedback.
    Thanks
    Andres
  •  06-16-2008, 5:30 PM 305636 in reply to 305622
    Re: Anybody Autocrossing an Evo in AS?
    Andres3165:
    Thanks
    Andres
    Yyou probably already know this, but in case you are new to autoXing...
    It seems most Evos run in STU - and do very well. You get a much lower PAX and a few nice mods. And, you don't have to change wheels at the event. In my small experience I have never seen an Evo in AS.
    Jason P.
    Indy Region Moderator
    SMS - M3 e46
    (STU in 2009 - Thanks SEB! :) )
  •  06-16-2008, 5:44 PM 305639 in reply to 305622
    One of our local guys in the Snake River Region runs his Evo in AS.  He ran it last year at the Salt Lake City Pro Solo and came in second in AS and then won the Pro Solo Super Hawk Super Challenge IIRC.
     Quick search: http://www.scca.com/newsarticle.aspx?hub=3&news=3147
  •  06-16-2008, 6:15 PM 305645 in reply to 305639
    I have seen the Evos run AS here in houston and they used to do rather well on their street tires. Nobody really tried to do much more.
    The STI has beter TQ but a well setup Evo in AS should do well nationally. I am thinking at least as competitive as the Boxster S I'm running now......so say a top 5 car.
    As for tires....easily 245 Hoosiers and maybe the 275s would clear the fenders. If so I'd look into them :)
    And maybe some trick shocks.....Motons or 2812s or ASTs or Penskes.
    David Hedderick
    Pearland (Houston), TX
    01 CRG YZ125 (FOR SALE! $2500)
    08 Mazda 3s
    92 Miata SE - Fun half-arsed STS2 Car
  •  06-16-2008, 6:54 PM 305653 in reply to 305645
    275s will clear the fenders, its the struts that get in the way.  I have to run 1/4 in spacers to keep the tires off the struts, and even then there is some rubbing still.  With that much added grip though, I think the car is still heavily undersprung, though it is possible a big ole front sway bar may help.
  •  06-16-2008, 11:33 PM 305719 in reply to 305653
    Here's the thread for stock class EVO's
    http://forums.evolutionm.net/showthread.php?t=57489
    And yes the front bar helps a little, especially in getting the rear back on the ground to get you back on the power sooner.  Also, I just switched to the Hankook 275/40s which are just a little less wide than the Kumho/Hoosiers, which seem to have reduced the rubbing.
    George M
  •  06-26-2008, 3:51 PM 307475 in reply to 305719
    Up here we have up to 3 in AS at an event.... conevadr being one of them and definately fast!
    Bret
    Camaro SS FS
  •  06-26-2008, 4:02 PM 307480 in reply to 307475
    Locally they do fine.  If I was going to prep mine for National competition, I'd get the custom Ohlins setup that Strano sells, do a big front bar, and 275 Hoosiers with the spacers.  I'm not sure whether the MR or the RS is the one to have.  The RS is lighter, but the MR has the 6-speed with a shorter 2nd gear.
    The thing is, you've now spent a pretty big chunk of what it would take to put the car in STU, and you'll make up the rest in tires very quickly (I got 5 events out of my Hoosiers).  You have a car that is at best an also-ran (I now drive a Z0K.  The Evo would not keep up.) whereas in STU its one of the two cars to have.
    Dave Heinig
    07 GXP Z0K (Thanks Rob!)
