G Stock MCS Setup Question - regarding lifting the inside rear tire on corner entry
Last post 07-14-2008, 12:03 PM by solo-x. 14 replies.
06-25-2008, 11:38 AM |
cmt52663
Joined on 04-16-2004
Wenham, MA
Posts 219
Points 3,010
Wise Folks,
There's a bit of debate on another forum regarding whether lifting the inside rear tire on corner entry is:
a. avoidable
b. indication of a setup opportunity - not desirable!
c. normal, not an issue
d. overdriving
My STX MCS does not do this but I'm running coil overs so I'm not surprised.
Should this behavior be tuned out with shock settings? Does it matter?
Thanks very much for your opinions on the matter.
Sincerely,
Charlie
Charlie Thompson '04 JCW Cooper [STX] NER Cannon Fodder
06-25-2008, 12:03 PM |
accordHS22
Joined on 08-15-2005
Morgantown, WV
Posts 67
Points 1,120
Re: G Stock MCS Setup Question - regarding lifting the inside rear tire on corner entry
Perfectly normal
The Brown Sean - #48 STS2 CRX
06-25-2008, 12:30 PM |
cmt52663
Wenham, MA
Posts 219
Points 3,010
thanks! not wishing to sound skeptical, but if you had DA shocks would there be any point in adding compression up front and a bit of rebound out back to try and dampen the pitch/roll on corner entry? it just seems intuitive to me that four wheels are better then three...
in addition, would you think it odd if the car three-wheeled through the middle of the corner - after the brakes are released?
cheers,
charlie
06-25-2008, 12:41 PM |
accordHS22
Morgantown, WV
Posts 67
Points 1,120
On my yellow CRX with the Koni DAs at full stiff on the rear the car would three wheel through the entire corner.
06-25-2008, 3:56 PM |
cmt52663
Wenham, MA
Posts 219
Points 3,010
thanks again - there's a picture worth at least a thousand words...
06-25-2008, 4:04 PM |
shinronin
Joined on 03-16-2004
Posts 108
Points 1,340
cmt52663:thanks! not wishing to sound skeptical, but if you had DA shocks would there be any point in adding compression up front and a bit of rebound out back to try and dampen the pitch/roll on corner entry? it just seems intuitive to me that four wheels are better then three...
more front roll stiffness is required if the inside rear is coming up i.e. a larger front sway bar and/or the shock changes you mentioned (front bump first, then rear rebound). what's more, sometimes the inside rear lifts because there isn't enough droop travel.
Doug #81 STS2 1990 Mazda Miata STU 2000 Audi S4 (retired) STU 2005 Mazda RX-8 (retired)
06-25-2008, 4:21 PM |
cmt52663
Wenham, MA
Posts 219
Points 3,010
shinronin: cmt52663:
thanks. i can see the tradeoffs get tricky right away - for the MCS stiffening the front roll bar would seem likely to increase the native understeer. if the stock bar permits enough chassis roll to exhaust rear droop in a steady state situation (those are rare though aren't they?) then there you are.
that lovely picture of the CRX seems to me to illustrate that situation very well - the chassis has quite a bit of roll, although it looks settled and quick.
i wonder though if the MCS has the same steady state characteristics, and wonder if any of our darned fast MCS folks are willing to comment?
06-25-2008, 4:31 PM |
shinronin
Posts 108
Points 1,340
cmt52663: shinronin: cmt52663:
yes, in the case of FWD a larger FSB won't help (iirc most if not all STS2 CRXs run with no FSB), but the pic is deceiving because setting the rear to full stiff with DAs isn't tuning out the inside rear lifting. in that pic imagine if the front wasn't rolling so much such that the car is not pivoting from front left to rear right. most ST* FWD suspension setups rely on a much higher rear spring rate compared to the front to induce more neutral handling. but, in the case of GS suspension limitations, some inside rear lift is probably inevitable but you can limit it with shock tuning.
06-26-2008, 11:12 AM |
shinronin
Posts 108
Points 1,340
yep, gotcha. my last post was done in a hurry and wasn't crystal clear but i was trying to describe both the MCS in STX and GS trim to address charlie's original post. i was trying to describe what charlie correctly identified as the tricky tradeoffs in grip vs. roll stiffness on a FWD car in stock trim. in GS, tire pressures, alignment, shock tuning are key. i was just pointing out that addressing three-wheel motion by tuning the rear won't help.
there's an article in the latest GRM addressing FWD setup on a MCS. check it out.
07-14-2008, 12:44 AM |
racnmni
Joined on 11-13-2005
Posts 24
Points 415
Just saw your post for the 1st time. The wheel up attitude of the Mini is completely normal and common among all the top cars. (see pic to your left) The R56 gets a bunch more air under there due to it's soft spring package. Since I'm trying to dial more rotation into the car most of the time... maybe 3 is actually better than 4 after all.
Tony Savini 2005 Mini Cooper S
07-14-2008, 7:36 AM |
cmt52663
Wenham, MA
Posts 219
Points 3,010
racnmni:
and that settles that! Thanks very much Tony.
Cheers,
Charlie
07-14-2008, 8:37 AM |
solo-x
Joined on 09-19-2003
Posts 897
Points 14,590
I'm trying to think of any point in vehicle dynamics where dynamically raising the CG is a good thing. Aside from drag racing, I can't think of any. If you want to talk more about it Charlie, find me at the next Devens event.
07-14-2008, 10:04 AM |
Stan
Joined on 10-28-2002
Ridgefield, CT USA
Posts 497
Points 7,010
As far as I know the only two examples where low CGs are not beneficial for handling machines = karts and dirt track racecars. On dirt a highish CG will help the tires dig into the dirt surface which increases total grip so the cornering speeds rise. For karts...since there is no differential and a huge F/R tire bias favoring the rear they want to understeer. So with a highish CG inside rear tire lift allows the thing to turn much more effectively. I think that is because basic kart design = Engineering nightmares where you have to fix one problem by creating others.
07-14-2008, 12:03 PM |
solo-x
Posts 897
Points 14,590
Stan:As far as I know the only two examples where low CGs are not beneficial for handling machines = karts and dirt track racecars. On dirt a highish CG will help the tires dig into the dirt surface which increases total grip so the cornering speeds rise. For karts...since there is no differential and a huge F/R tire bias favoring the rear they want to understeer. So with a highish CG inside rear tire lift allows the thing to turn much more effectively. I think that is because basic kart design = Engineering nightmares where you have to fix one problem by creating others.
Ah, didn't think of dirt, and karts I class under "anomalous".
