FS: Shifter Kart Package (with enclosed trailer) $2500 (PRICE DROP)
Last post 09-16-2008, 11:41 PM by Davebs14. 20 replies.
Page 1 of 2 (21 items)   1 2 Next >
  •  05-21-2008, 1:19 AM 301399
    Shifter Kart and enclosed trailer for Sale:
    2001 CRG Heron Plus
    2001 YZ125cc motor with mild cylinder and head work (ports cleaned up and head shaved 0.010) - 6 speed trans - I am told it should produce about 38HP in this configuration
    (the motor has some cosmetic JB weld on the side but has no leaks from the damage....was from previous owner)
        - top and bottom fresh as of March with maybe 0.5 hours....ALL OEM Yamaha parts used
        - Motoul Trans-expert 10w30 tranny fluid
        -Redline 2 stroke racing oil used in motor
        -OEM Mikuni carb with assortment of jets
        -K/N filter with airbox and extra filter as well
        -Vforce 2 reedcage (best one made) (stock one included)
        -RLV pipe (older model....not sure what)
        -NEW plug, wire, and boot
        -Plugged and machined power valves (originals included)
    -27T Aluminum rear gear and 15T main gear
    -new 40mm hard shockwave rear axle with all new rear bearings
    -Extra long hubs, but includes Medium length as well
    -new bearings in LF and plenty of extras to replace for years
    -Tillett XXL full pad seat (fits drivers in the 180-220lb range (I'm 200lbs and 511 in my suit and helmet)
    -has the desired CRG self adjusting brakes (not the VEN ones)....2000 up I think they might be called? it's got 2 calipers on the rear foating disg as well
    -Mychron lite  with EGT, H2O, CHT temp probes.
    -nearly new Banana style radiator
    -4 seat struts (2 home made)
    Comes with like a 4 or 6 liter tank mounted but includes the BIG oem CRG tank
    SPARES:
    -extra set or two of brake pads I believe for the front
    -plenty of spark plugs 3 Iridium NGKs and 3-4 NGK-R plugs
    -tire bead breaker and tool to change your own tires
    Wheels and tires:
    -OEM mag CRG wheels (CRG hubs incl.) with some 80% worn rears and 30% worn fronts MG Green tires
    -CIK alum wheels (130F 210R) with Vega XP tires 80% worn rears and 30% worn fronts (vega rears dismounted and YHA...soft Bridgestones mounted now)
    -RKP wheels alum wheels (130F 210R) with Bridgestone YHB (medium soft tires....spec for most shifter classes)  30% worn rears and 10% worn fronts
    -Douglas vented Mag wheels (130F 212R) almost new wheels with almost new Vega XP tires (only 6 min run time on sealed asphalt in autocross)
    -Douglas Rain wheels with Bridgestone Rains.....only 3 autocross runs on them in a downpour
    - 2 extra YHB fronts unmounted
    Homemade enclosed trailer 5x8:
    -cost $350 new when I bought it 3 months ago from Northern Tool
    -Has C load Range tires on it and a B load range spare mounted up front. Also has a trailer jacking wheel up front to make it easy to maneuver in the pit and at home
    -enclosed rear 6 ft of trailer for kart with 3/4" thick plywood and 2x2in angle iron  (polyurethane coated wood 2x on outside 3x on bottom and 1x inside) (spent about $700 in parts)
    -it wasn't welded totally straight but is weather tight
    -ugly enough to not get stolen but solid enough to use as a viewing platform (why i built it)
    -front is open for alum box not yet added on, but included
    -enclosure only 2 ft high so the kart barely fits, but sits low enough to tow out of the wind.
    -I tow it with my Mazda 3. Milage goes down only 2MPG (28mpg on the highway towing @80mph). That's why I built it so low instead of buying a built one for $1800.
    I KNOW there is more that I have forgotten, so I may be adding more. I was also told that it leaves the line as fast as any fully built Honda (by a local Honda guy with a 42hp motor.....he said mine was faster than his). The YZ i'm told makes more Torque so its wayyyyy easy to drive. :)
    OVER $7000 INVESTED IN THE LAST YEAR AND A HALF. I've fixed everything on the kart that could need fixing. It's run strong and only ever broken down of my own fault. I am moving on and building a Miata for the track/street so this has to go to clear Garage space
    PRICE DROPPED TO $2800 with the trailer and $2600 without.
    DROPPED AGAIN to $2500 with the trailer.
    David Hedderick
    Pearland (Houston), TX
    01 CRG YZ125 (FOR SALE! $2500)
    08 Mazda 3s
    92 Miata SE - Fun half-arsed STS2 Car
  •  05-28-2008, 11:31 PM 302820 in reply to 301399
    Re: FS: Shifter Kart Package (with enclosed trailer) $3000
    PICS ADDED BELOW!!!
    http://s128.photobucket.com/albums/p181/miata_racer/Kart%20Pics/?start=all
    David Hedderick
    08 Mazda 3s
  •  06-03-2008, 4:37 PM 303718 in reply to 302820
    Sent an email.  You can PM me too.
  •  06-03-2008, 10:33 PM 303759 in reply to 303718
    PM sent
    Chase Heikkila
    89 CRX Si - STS2
    -the one with orange wheels-
    Cincinnati Region
  •  06-04-2008, 12:43 AM 303785 in reply to 303759
    replied to all :)
    David Hedderick
    08 Mazda 3s
  •  06-04-2008, 2:50 PM 303885 in reply to 303785
    I just sent you a pm david.
  •  06-04-2008, 7:53 PM 303944 in reply to 303885
    i messaged you back :)
    David Hedderick
    08 Mazda 3s
  •  06-05-2008, 3:34 PM 304090 in reply to 303944
    PM sent.
  •  06-05-2008, 11:15 PM 304161 in reply to 304090
    david,
    do you know if the previous owner/s of this kart used it for road racing?
  •  06-09-2008, 12:36 PM 304542 in reply to 304161
    The guy before me did use it for racing.
    The JB weld on the side of the motor was for a surface crack. I took the cover apart and couldn't see any damage inside the case. So its just cosmetic. It apparently hit a curb and fence.........the driver absorbed most of the impact I was told :)
    So the frame was tweaked about 1/2" on the right side. They had it straightened at a kart shop here in Houston. I never noticed any problem with the kart besides the current driver's lack of discipline :)
    I also have a straight intake on the way I was told (something I ordered 2 months ago and had forgotten about). Its supposed to make 2-3 more HP and TQ!!!  :)  And the reason I bought it is to make the air box fit better when i run in the rain :)
    So that's included......
    ALSO.........since there is interest without the trailer....I will knock $200 off the price. Mainly because I was ordered to get rid of the trailer or get a smaller one LOL........so I can keep this one and modify it to fit my needs :)
    I also calculated shipping to central OH....its about $500 to a residence. So thats a general idea for those who aren't too close to me :)
    David Hedderick
    08 Mazda 3s
  •  06-09-2008, 5:24 PM 304632 in reply to 304542
    Pm sent
  •  06-27-2008, 12:18 PM 307642 in reply to 304632
    Due to the increase in hours at work I cannot deliver it more than about 400 miles now :(
    It is still for sale though.
    It also includes a custom straight intake good for another 2-3hp I'm told.
    David Hedderick
    08 Mazda 3s
  •  06-28-2008, 8:42 PM 307770 in reply to 307642
    I will sell it without the trailer. And if need be, I'll deliver it to topeka in september. :)
    Make me an offer.....I have 2 project cars coming in the next week
    David Hedderick
    08 Mazda 3s
  •  07-02-2008, 12:27 AM 308239 in reply to 307770
    Re: FS: Shifter Kart Package (with enclosed trailer) $2800
    price drop to $2800 with the trailer and $2600 without it.
    David Hedderick
    08 Mazda 3s
  •  07-13-2008, 11:22 PM 309987 in reply to 301399
    Re: FS: Shifter Kart Package (with enclosed trailer) $2500 (PRICE DROP)
    OK...dropping the price to $2500 with the trailer. I need it gone......I'll have to part it out it I don't sell it.
    David Hedderick
    08 Mazda 3s
  •  07-23-2008, 10:38 AM 311635 in reply to 309987
    Good for breaking up gall and kidney stones for easier passage :)
    David Hedderick
    08 Mazda 3s
  •  07-24-2008, 7:55 PM 311992 in reply to 311635
    With the amount of fluids I drank at Houston, I'd probably have soaked pants by the end of the 4th run.
  •  08-18-2008, 10:52 AM 316207 in reply to 309987
    Still interested, sent email.
  •  08-18-2008, 1:14 PM 316238 in reply to 316207
    Reply sent :)
    As of now, I'm not planning on taking it to nationals to show. I simply don't have the extra $260-300 to bring it there and back in my budget. :(
    But if its to deliver it to the buyer, I can do that.
    David Hedderick
    08 Mazda 3s
  •  09-11-2008, 2:16 PM 320955 in reply to 316238
    Sent you a PM
    -Mike
    #17 STS RSX-S
