If you take a Miata bushing apart, you'll find that the normally visible metal parts give the impression that there is minimal metal in the bushing. In fact, there is a huge knot of metal in the middle. It would be very unlikely that aftermarket bushings would have an equal or greater amount of metal.
As far as Urethane vs Delrin, I'd avoid non-bonded urethane. In order of performance I'd use stock OEM Mazda bushings, Mazdaspeed stiffer bonded rubber bushings, bonded urethane bushings, then delrin. Non bonded urethane bushings have all the disadvantages of delrin, but miss some of the advantages. The only advantage that non-bonded urethane has is cost, and the difference in cost will be quickly forgotten after they become a PITA to maintain.
