REAL weight of a CSP MR2 Spyder
Last post 07-19-2008, 12:32 PM by Rocwandrer. 8 replies.
  •  07-06-2008, 10:15 AM 308677
    We are about to class the MR2 Spyder in Improved Touring and I can't wrap my arms around this car having a 2195lb curb weight (Edmunds.com).  If it does, it's going to be ITS.
    Andy Bettencourt
    Flatout Motorsports
    New England Region
    www.flatout-motorsports.com
  •  07-06-2008, 12:01 PM 308685 in reply to 308677
    Re: REAL weight of a CSP MR2 Spyder
    My stock class prepped car is around 2140 pounds sans driver.
    Godspeed.
    --Wayne
    www.WalterMotorsports.com
  •  07-06-2008, 12:03 PM 308686 in reply to 308677
    In Solo stock trim my car was 2170.  With A/C, stock seats, light but full size rims, hoosiers, etc.
    Rob Leone
    '07 Solstice GXP in AS
    '87 Toyota Corolla in EP
  •  07-06-2008, 10:01 PM 308739 in reply to 308686
    2002 and earlier models are the lightest...03 a bit heavier, with 04's being the heaviest as Toyota added some "safety bracing"...
    Tracy Ramsey
    Team Blenderblaster
    2000 MR2 DP Spyder
  •  07-07-2008, 10:00 PM 308973 in reply to 308739
    Can't give you any input on power with IT mods, but a bone-stock 2000 MR2 puts about 10% more hp to the wheels than a bone-stock 99-2003 miata.  And you already know it weighs considerably less.  Sounds like ITS material to me.
  •  07-08-2008, 1:16 PM 309097 in reply to 308973
    Thanks for the info guys.  I am guessing this would be in the area of a 2275lb ITS car or a 2550lb ITA car.  I would think guys would want to search out the OEM hardtop to run in IT so that would add some weight.
    Andy Bettencourt
    Flatout Motorsports
    New England Region
  •  07-08-2008, 4:10 PM 309147 in reply to 309097
    Well, I run D Prepared solo, and have my car down to 1900 pretty easily, including the rollbar.   I don't know the roadracing rules, but if you run the hard top, can you delete the soft top?   That is going to probably be close to a push.   the big weight is the rollbar, which weighs 135# in my car.
    Tracy Ramsey
    Team Blenderblaster
    2000 MR2 DP Spyder
  •  07-09-2008, 8:25 AM 309273 in reply to 309147
    Weights in IT are including driver (assumed to be 180lbs) so the actual car would be in the 2070lb range....
    Andy Bettencourt
    Flatout Motorsports
    New England Region
  •  07-19-2008, 12:32 PM 310994 in reply to 308686
    a bone stock spyder puts about 120 hp to the wheels.  It have excellent low end power for an N/A 1.8l (under 4000 rpm).  It doesn't respond as well as the average import to the typical mods (intake, header, exhaust, etc).  There's maybe 15 peak whp in a standalone ecu replacement with I/H/E (the ecu is necessary to get most of this).
    The 2000-20003 all weigh within about 5 lbs of each other in csp trim since the weight was in stuff like seats, full sized vs donut spare, etc.  the 04-05 might be able to have their front offset/toe box intrusion crash braces be backdated to the same weight as the early cars.  It is relatively difficult to drop weight from this car.  stock wheels are heavy, but interior stuff isn't, and there is barely any sound damping material, the stock battery was only 28 lb, etc. I'd say 1900 lb plus roll bar and driver is achievable in IT trim (based on what I remember from ITA rules from the 90's).
    toyota's GVWR is in the neighborhood of 2550 lbs.....
    the hardtop was never officially available from toyota in the US.  does that matter?
    WTB: CSP Spyder parts. What you got?
