Best 285 tire?
Last post 10-25-2008, 2:01 AM by imstimpy. 17 replies.
  •  09-24-2008, 1:51 PM 323279
    Best 285 tire?
    Now that 285 will be allowed in STU for RWD/FWD, I did a quick check at TireRack.... not too many options out there.
    There is a clear leader in Yokohama ADVAN Neovas - but those cost $358 a piece (285/30R18)! There don't seem to be 285s from the other tire leaders (Dunlop Direzza Star Spec, Bridgestone RE010) - any chance they they will release new tire sizes by next year?
    What about a cheaper alternative like the Kumho Ecsta MX that is less than half the price (285/40R17 = $157)? That is cheap enough to offset the cost of new 17" wheels. I don't think I have seen any top drivers use this tire though - is it any good?
    Any other good options out there?
    Jason P.
    Indy Region Moderator
    STU - M3 e46
  •  09-24-2008, 2:18 PM 323290 in reply to 323279
    Re: Best 285 tire?
    The Kuhmo MX is not a great choice compared to the other tires now plus it is being replaced with the XS.  The closest sizes I see are a 275/35/18 in the Dunlop and the Kuhmo XS.  So your choices at the moment seem to be spend the big money on the Yokos or go for the 275 Dunlop or Kuhmo for less money.
    Keith
    2008 Honda S2000
  •  09-24-2008, 2:34 PM 323292 in reply to 323290
    • jzr is online. Last active: 12/02/2008, 5:59 PM jzr
    • Top 75 Contributor
    • Joined on 10-20-2002
    • San Diego, CA
    • Posts 838
    • Points 12,350
    Re: Best 285 tire?
    For a car with some heft and/or HP that'll fit 'em, I'd go for the 285/35-20 Dunlop DSST, the stickier of the two tires available on the back of the new GTR.
  •  09-24-2008, 2:52 PM 323298 in reply to 323292
    Re: Best 285 tire?
    jzr:
    But, those are Run Flats - and even more pricey than the Yokos. (and weigh 40lbs.)
    Jason P.
    STU - M3 e46
  •  09-24-2008, 3:05 PM 323302 in reply to 323279
    Re: Best 285 tire?
    You're looking at 18 or 19" wheels for the top tires (Dunlop, Bridgestone) and that would be a 275.
    Brian Davis, 89 Civic Si, 158 STS
  •  09-24-2008, 3:57 PM 323323 in reply to 323302
    Re: Best 285 tire?
    turbohappy:
    So, you think most people in STU with RWD/FWD are going to just stick with 275 then despite the new allowance for 285?
    Jason P.
    STU - M3 e46
  •  09-24-2008, 4:02 PM 323326 in reply to 323323
    Re: Best 285 tire?
    that was already the reality for 2wd STU cars given that a 265 was the best (yok, b-stone) widest tire available when the allowance was 275.  a 275 615 just didn't cut it.  Wink
    Doug #81 STS2
    1990 Mazda Miata
    STU 2000 Audi S4 (retired)
    STU 2005 Mazda RX-8 (retired)
  •  09-24-2008, 6:20 PM 323344 in reply to 323323
    Re: Best 285 tire?
    The Nebulizer:
    turbohappy:
    You can run 225s in STS and almost everyone is on 195s. A better tire is still better even if it's a little narrower.
  •  09-25-2008, 9:18 PM 323635 in reply to 323344
    Re: Best 285 tire?
    I'm not as in tune with the latest tires since I dropped out of STU this year, but the 265/35 Advan Neova was considerably wider and shorter than any of the other 275/35 tires available previously.  A 285/30 will be shorter and wider still, so there's potentially a gear advantage or disadvantage at play depending on the application.
    If it were me I'd play the waiting game before making any particular commitment.  A lot can happen between now and the early half of the 2009 season.  I'd expect the serious manufacturers to step up with this size once it's certain that it will be STU legal.  The old 275 limit is why most of them don't offer a 285 yet .... yet.
    "Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car.
    Horsepower is how fast you hit the wall, torque is how far you take the wall with you." --Anonymous
  •  09-26-2008, 12:31 AM 323680 in reply to 323635
    Re: Best 285 tire?
    This sounds like a great new rule change that TONs of people are going to be able to utilize...
    Ryan K
  •  09-26-2008, 12:32 AM 323682 in reply to 323635
    Re: Best 285 tire?
    TeamRX8:
    Thanks for the info - didn't know that about the Yoko 265s (they are your old tires BTW Wink ) I'll definitely not buy anything until next year - just trying to plan my attack. I was thinking of going to 17" wheels possibly. Hopefully, there will be more options in 285 by next year.
    Jason P.
    STU - M3 e46
  •  09-28-2008, 10:42 AM 324084 in reply to 323682
    Re: Best 285 tire?
    285/30/18 is awesome as its nice and short compared to other tires, at least for a 240sx, fitting the fronts with massive tires this is the way to go but there aren't many 285/30/18 options i wish more tire companies would go this route and produce more sizes... heck even 335/20 or 25/19 or something would be an interesting albeit expensive sizing to keep the tire nice and wide yet short... I plan to fit some 285s up front and 3xx in rear when I swap a v8 in it next year... i have clearance issues and wanna keep everything nice and right... whether its legal or not in this race class... regardless I wish these sizes would become possible...
  •  09-29-2008, 9:07 AM 324189 in reply to 323682
    Re: Best 285 tire?
    The Nebulizer:
    TeamRX8:
    We have and E46 M3 with comp package.  17" rims will not fit.  Have you tried a 17 on your car, or do you just assume it will fit?  The comp package on our car has much bigger rotors, but I thought the calipers were the same.  17" rims hit the calipers, a good bit.
    125 STS '89 Civic Si
    RPGproduction.com/Toyo Tires/Moton/NABC-Ethanol Racing
  •  09-29-2008, 9:17 AM 324191 in reply to 324189
    Re: Best 285 tire?
    TimSmith:
    The calipers are the same, but they sit out farther on the ZCP due to larger rotors (I have non-ZCP). I have read many reports (m3forum.net - racing section) of people running 17s. I am sure not all 17s fit, several are supposed to - like Kosei, TR motorsports, 330i sport wheels, some BBS, etc. I believe some are supposed to fit on ZCP even. Many people run 17s for winter and some do for track too. Which 17s were you trying? (are they for sale?Stick out tongue )
    Jason P.
    STU - M3 e46
  •  09-29-2008, 4:42 PM 324295 in reply to 324191
    Re: Best 285 tire?
    When looking at tire choices, don't discount the overall height of the tire and it's effect on your gearing.  That could be more important than the 20mm width difference of a 265 vs 285.  I'd look at your 2nd gear mph limit try and pick an overall height that allows you to not shift if possible on an vast majority of courses you will encounter.  For example, in a '05 STi I had to shift to 3rd and back to 2nd twice on both courses at Nationals and bumped the rev limiter a few times as well.  If I could change the gearing via tire height and eliminate either one of those shifts or bumping the limiter (which slows my acceleration), I know I could pick up .5 seconds.
    If comparing 17" vs 18" wheels, I think 18's are the way to go as you probably will gain overall height while not having to run a tall sidewall.
    Jason McCall #47 STU
    '00 M Roadster - XP (under construction)
  •  09-29-2008, 6:53 PM 324326 in reply to 324295
    Re: Best 285 tire?
    McCall:
    That's a good point. For my car I haven't had any trouble with 25.3" diameter 265s (stock being 26"). The only 285s I know of (Yoko) are even shorter at 24.8" - I think I would still be fine (I have never hit the rev limit in 2nd - but 1st a couple times... oops Stick out tongue)
    Jason P.
    STU - M3 e46
  •  10-05-2008, 12:55 PM 325360 in reply to 324191
    Re: Best 285 tire?
    The Nebulizer:
    TimSmith:
    That makes sense.  The rims I was trying were the 330i sports, it was a while ago, I don't have them anymore, as you know, they are heavy and definitely not wide enough.  Good luck in your venture.  I will be keeping an eye out.
  •  10-25-2008, 2:01 AM 329140 in reply to 323279
    Re: Best 285 tire?
    The Nebulizer:
    Yokohama AD07 285/30/18
    Yokohama AD07 265/35/18
    Toyo R1R 275/40/17
    Toyo R1R 265/35/18
    Kumho XS 285/40/17
    Kumho XS 275/40/17
    Kumho XS 275/35/18
    Kumho XS 265/35/18
    Bridgestone RE-01R 265/35/18
    Bridgestone RE-11 265/35/18
    Dunlop Z1* 275/35/18
    Dunlop Z1* 265/35/18
    There are a few more options if you consider 19s and 20s.
    The Nebulizer:
    I thought about 17s, but the wheel sizes are simply not available. The Volk 17x9.5+42 was the largest I found without going custom. D-Force has been the only lightweight 18x10 I have come across so far.
    The Nebulizer:
    The E46 M3 is unique in-so-far as it has a stock 26.0" rolling diameter. The E36 M3 had a 24.7" rolling diameter and always saw a gearing disadvantage when going wider. At 26.0", though, all the weird sizes are no taller and many are quite a bit shorter.
    I was going to do my initial development on a set of 255/40/17s I have from my E36. It will be a few months into next season before I have to actually pull the trigger on something.
