1. first, be sure the bushings need replacing. it's a lot of work. just b/c they're old doesn't mean they need to go. i still have the original busings on my 238,000-mile street-driven '91. but a lot of people have a lot of opinions on this subject.
that said, the mazdaspeed bushings are rubber like the OE bits (but stiffer than stock). they won't need maintenance. the poly bushings will need maintenance, as will the delrin. Andy Hollis had a nice blog about his STS2 build floating around here, GRM, and miata.net. one post specifically discussed delrin bushings.
2. is your heart set on GC sleeves? you can pick up a set of Koni sleeves for ~$100, or buy a set of "ebay" sleeves (~$30) and source your own springs. the latter is on my car, and it works perfectly.
what are you doing for top mounts? adding more suspension travel back onto a lowered miata is important, IMO. if you haven't already, consider either a set of modified NB mounts, the FatCat mounts, or the flyin' miata rear mounts. they'll let you lower the car without constantly riding on the bumpstops.
Mike - #44 STS2
'91 Miata - racer
'07 CX-7 - dog taxi
www.phillyscca.comwww.GreyhoundAngelsAdoption.com
