sts2 crx setups
Last post 09-29-2008, 7:08 PM by solo-x. 125 replies.
Page 1 of 7 (126 items)   1 2 3 4 5 Next > ... Last »
  •  11-05-2004, 10:25 AM 81552
    sts2 crx setups
    So I've read ChrisShen's setup notes on the Civic, and in a civic I'd be inclined to go with his recommended 400f/450r spring rate for a weekend-warrior/daily-driver.
    Now I'm building a 91 CRX Si for STS2, and I'm wondering how those spring rates will translate to the shorter crx chassis... the weight of the vehicle is similar, but the f-r ratio might differ some. I've seen some folks talk about using 400/400 on crxs as well.
    Do you think 400/450 would be a good all-around spring setup for an autocrossed daily driver or is there another known setup the csp or ep or sm2 folks have found to work best?
    '91 CRX Si (STS2)
  •  11-08-2004, 7:15 AM 81553 in reply to 81552
    Re: sts2 crx setups
    I'd be looking at something more along the lines of 550-600 lbs up front and 450-500 lbs out back, but that's just me.
    Also really depends on the shocks you choose.
    2006 Ford Focus ZX3.
  •  11-08-2004, 8:05 AM 81554 in reply to 81553
    Re: sts2 crx setups
    Ahh, OK, I've been seeing that the typical auto-x setup for CRXs is much different from the civics...more bias up front.
    Still, those rates sound insane for a daily driven autoxer. :eek:
    '91 CRX Si (STS2)
  •  11-08-2004, 10:05 AM 81555 in reply to 81554
    Re: sts2 crx setups
    Can someone explain why a CRX would have more of a bais toward the front? I know it has a shorter wheelbase than a Civic, but I've seen many Civics with a very stong bias towards the rear, so why wouldn't heavier springs in the rear also benefit a CRX?
    Bill Bounds
    96 STS
    1989 Civic Si "H. Dumpty"
  •  11-08-2004, 10:16 AM 81556 in reply to 81555
    Re: sts2 crx setups
    Its important to note that the 88 CRX is from the 89-91's. Whats good for an 88 is not neccessarily optimum for a 89-91.
    Now alot of roadrace CRXs are putting high bias in the rear as well, but all the crx "kits" generally come with higher fronts off the shelf.
    '91 CRX Si (STS2)
  •  11-08-2004, 10:36 AM 81557 in reply to 81556
    Re: sts2 crx setups
    I'm driving a 91 CRX Si, so I am interested in this question too. My concern is that a "kit" is not the best way to go (and not what I was considering) because of the front bias. So I was wondering why the front bias was suggested, as it is contrary to what I have been reading recently regarding Civic setups.
    Bill Bounds
    96 STS
  •  11-08-2004, 6:08 PM 81558 in reply to 81557
    Re: sts2 crx setups
    bottomline, do whatever works for j00!
    i subscribe to the "run as soft as you can and still win" school of thought, if that helps.
  •  11-09-2004, 7:36 AM 81559 in reply to 81558
    Re: sts2 crx setups
    me too. :D
    '91 CRX Si (STS2)
  •  11-09-2004, 8:09 AM 81560 in reply to 81559
    Re: sts2 crx setups
    Because it doesn't take much to get the CRX's to rotate, especially on street tires. I'd start out with something like 450/450 and go from there. Heck, with the proper alignment, camber settings and springrates, I seriously doubt you'd even need to upgrade the rear swaybar.
    Todd
    Too many ST cars
    "Restricted Area Racing"
  •  02-03-2006, 3:32 PM 175724 in reply to 81560
    Re: sts2 crx setups
    Granted I'm new to this, but I was running a 90si in sts2 last year, I have since bought an 88 (with 62k original miles ;) ) and am building it for 06 or 07!!
    Back to the point at hand.. I ran the 90si as a daily driver, with 400 ft 450 rr, and had the progress rear sway, adj to full stiff, and I think it rotated great, I had it figured out pretty well to get it to kick out enough I could get back on the throttle out of the corner.  Now I am the 'slower brother' compared to my EP brother, but I liked that setup, and think I'll end up around 450/500 to start off with on this new project, that will be a strict STS2 car, since I won't have to use it as a daily driver.  WOOHOO!!Big Smile [:D]
    »Coining the phrase... Clarifi-Change...
  •  02-04-2006, 10:47 AM 175791 in reply to 175724
    Re: sts2 crx setups
    Well its time to check in on this old thread, I suppose.
    I've been really happy with the CRX so far, and currently its on 450f/400r with a ST rear sway bar on full soft, and a CRX HF front bar. I'm happy with this setting, just need to drive it better. :P
    '91 CRX Si (STS2)
  •  06-28-2007, 12:29 PM 251411 in reply to 175791
    Re: sts2 crx setups
    A year and a half later, who is up for sharing their spring rates on the STS2 Rexs?
  •  06-28-2007, 1:37 PM 251430 in reply to 251411
    Re: sts2 crx setups
    450/500.
    I tried 380/500 and felt it was too loose in fast transitions, and I like loose.
    '91 ITB Civic DX
  •  07-02-2007, 9:30 AM 251814 in reply to 251430
    Re: sts2 crx setups
    What's funny is that a lot of people I talk to in impound are running completely different set ups and everybody is running similar times.  Some people left foot brake so they can drive a car that's real loose.  Some people don't so they need a more stable car...  Different strokes for different folks and to tell you the truth, I dont' think spring rates and all that mean that much compared to how well you can drive.  You just have to set the car up for your driving style and keep at it.
  •  07-02-2007, 9:46 AM 251817 in reply to 251814
    Re: sts2 crx setups
    I would tend to agree. I wasn't left foot braking a year ago, and as soon as I started and lost that giant weight transfer rear to front.. a car that was point and shoot, became a gravel plow. I spent the next few events tweaking rates, and setup again. Spring rates, bar choices, shock settings, pressures, etc. are definitely driver dependant, "good choices" are relative to the driver's style.
  •  07-02-2007, 9:55 AM 251820 in reply to 251817
    Re: sts2 crx setups
    Still 450/400, and still learning to drive it.
    One thing I think stands true universally for all the CRXs I've seen... rear camber is one of the biggest factors in getting the CRX either settled down or looser, depending on what you're looking for.
    '91 CRX Si (STS2)
  •  07-02-2007, 10:32 AM 251829 in reply to 251820
    Re: sts2 crx setups
    David McKnight:
    Tongue Tied Understood, not only did I just run my (presumably) last event on my funky 14's (toyos), but did some severe camber corrections to the rear, enough that it was incredibly loose and twitchy at our local event yesterday... a couple DNFs, tons of cones, borderline un-drivable. Some 'Stones will be on it by week's end, do some camber and toe adjustments before the next event. As well as working more on a carbon fibre intake.
  •  07-02-2007, 11:42 AM 251848 in reply to 251829
    Re: sts2 crx setups
    I have owned a 1988 CRX Si back in the day. Even with all seasons on the car in the winter was a handful. So I would have to agree the 89-91 Civic Si would be a handful for the 88-91 CRX Si. But it really depends on the driver.
     From memory the weight dist was something like 63/37 or 62/48. And the Civic was more 60/40.
    KAM Racing Sports, Falken Tires, Progress Technology, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes
    Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO!
    Buy my Civic parts!
  •  07-02-2007, 5:59 PM 251955 in reply to 251848
    Re: sts2 crx setups
    430/500
    Not very loose.
    The Brown Sean - #48 STS2 CRX
  •  07-02-2007, 10:50 PM 252005 in reply to 251955
    Re: sts2 crx setups
    400/450   Plenty loose....
    OzCop
    "It's never too late to have a happy childhood."
